SSS DIO ZX and SP import thread
lowblueranger
Re: Finally getting an authentic super dio!
Post by lowblueranger »
I love the black and blue Dio ^^^
Awesome!!!!
Xxbeejay45xx
Post by Xxbeejay45xx »
That scoot is in great shape! Great connection you have there. Very nice looking DIO
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
Polini vari, clutch, springs
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Front and Rear disc brakes
Dio Live headset
Stretch and fatty rear wheel
1man8scoots
Post by 1man8scoots »
Do you want me to get the af18 from patrick powder coated same color or just bead blasted? I'm going to do a ton of measurements on the af18 before porting so we can have an accurate measure of the volume and dimensions of it compared to the af16.
birdman
Post by birdman »
very very nice my friend.
92 Yamaha Jog CY50
98 Yamaha Zuma
00 Honda Elite 50SR
82 Honda MB5
90 Honda NS50F
14 Yamaha FZ-09
16 Kawasaki Versys 650
Hppowdercoatings
Post by Hppowdercoatings »
graphite9 wrote:1man Im not eve sure what that motor is going into. For right now lets just get it cleaned up. Unless you have a good source to coat it local.
I will offer 10% off Powder coating for any Hondaspree.net Members. And will Donate that 10% to Hondaspree.net Website....I'm located in St.charles, Missouri..
1man8scoots
I can bring it by tims if I go out there next weekend. He does great work!
KingJeff801
Post by KingJeff801 »
Sick motor! can't wait to see it mounted!
:peace:
J
2001 Elite S
72cc Corsa
24mm OKO
Scorpion Pipe
Pic and Vid post
Gun Post
Wrong Side Kings 4 Life
sanjuro
Post by sanjuro »
Woah, motor looks clean as heck. You should really look into getting a parts manual to source all the bolts and whatnot.
Rip_City_Spree
Post by Rip_City_Spree »
d*** i need to come over and check her out.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
Naraku sport variator
Currently 5g rollers
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
1man8scoots
Use your nip from the manifold just like you would a normal vacuum style petcock.
Looks sweet!
1man8scoots wrote:Use your nip from the manifold just like you would a normal vacuum style petcock.
Looks sweet!
I'm not sure that will work/
fuel pump needs to be hooked to the case after the reeds not before.
curtis966
Post by curtis966 »
Pretty sure you can just move the nipple to the bottom half of the intake and seal the original hole, that way it is below the reeds. Pretty sure that's what downsouthdio did on his.
veedubh20
Post by veedubh20 »
Yap the reason why fuel pump vaccum fail.. need to tap below the reed valve on buttom intake manifold.
The af16 block don't have a brass fitting below the starter.
Yes on gavaity fuel tank , you can on oil pump plug add a nipple or stock oil pump , remove the shaft. Need a rubber cap on Oil line.
1man8scoots
Oops, they are correct. Ha I must have been sleepy. Extra work on top of everything I need to slow down and read what I write before giving poor advice.
Downsouthdio
Post by Downsouthdio »
Like so :thumbwink:
Honda super dio
Corsa
26mm
Sparrow
