ped
Posts: 1598 Joined: Sun Sep 29, 2013 9:54 pm
Post
by ped » Mon May 25, 2015 1:52 am
Hi forum.
all scoot motor photos are welcome.
we had some great photos, in all different stages.
if you wish to add more motor photos in any stage. please do.
let's make this a great thread.
50cc stock
50cc stock 20150525_012435.jpg (187.9 KiB) Viewed 9453 times
maddog
Posts: 2171 Joined: Mon Jul 23, 1973 10:24 am
Post
by maddog » Sat May 30, 2015 1:42 am
Hey broke back kid try using what god gave you, and what sorry state are you from
paulpauly7
Posts: 1684 Joined: Tue Feb 21, 2012 6:57 pm
Post
by paulpauly7 » Sat May 30, 2015 3:19 am
Maddog no pic no post P. O .
1man8scoots
Posts: 1119 Joined: Wed Mar 18, 2015 11:49 am
Post
by 1man8scoots » Wed Jun 03, 2015 3:23 am
Last for the night, polini corsa unported, af16 unported, stock gears.
Downsouthdio
Posts: 835 Joined: Wed Dec 21, 2011 11:00 am
Post
by Downsouthdio » Wed Jun 03, 2015 7:14 am
Looks like my old block,look at that boost!
Honda super dio
Corsa
26mm
Sparrow
veedubh20
Posts: 1667 Joined: Sat Dec 31, 2005 7:00 pm
Post
by veedubh20 » Wed Jun 03, 2015 1:44 pm
the stage6 is a speedfighter, rod length is shorter than dio. 41.4mm
1man8scoots
Post
by 1man8scoots » Wed Jun 03, 2015 4:30 pm
veedubh20 wrote: the stage6 is a speedfighter, rod length is shorter than dio. 41.4mm
You've done this swap or just stating the obvious? If you have you'd know the SPEEDFIGHT used a 39.1 stroke and this kit uses ultra low 170 exhaust port duration with a 120 transfer. Which by any means is low on the rpm scale. Add a bit of base to it and you get a much better timing profile with great ports.
Just saying if you're going to correct someone be correct. Post up something vdub, I know you have something cool for sure.
1man8scoots
Post
by 1man8scoots » Wed Jun 03, 2015 7:44 pm
Malossi iron bore slightly ported and definitely cleaned up, malossi wild lion, malossi reeds, stock carb, stock block and crank, malossi cdi, stock air filter, 82 jet @5800 feet 9.8:1 gears. The girl friends elite engine.
The only elite at the house with electric start and quiet. Just built today and still doing heat cycles. Yay...
davmad
Posts: 15 Joined: Sat May 30, 2015 10:09 am
Post
by davmad » Tue Jun 09, 2015 5:27 pm
My engine before any work has been done
2015-06-09 17.25.57.jpg (250.19 KiB) Viewed 9314 times
ped
Post
by ped » Wed Jun 10, 2015 3:06 am
this motor would be nice to do a Spreemax motor swap
scootfast
Posts: 82 Joined: Sat Aug 30, 2014 5:20 pm
Post
by scootfast » Tue Jun 23, 2015 2:22 pm
My motor looks great wish I could touch it.Jim
ped
Post
by ped » Sat Jun 27, 2015 2:27 pm
Sweet looking motor jim.
I been swapping my motor over for testing purposes.
It has an excellent take off, great mid range, working on top end speed. Only going 65mph for now.
