LED lightbulbs
Re: LED lightbulbs
Yeah the 3000k look nice. They bean has a cool almost polixles lasee effect when you look at it. I use them on my gogs on one of my cars.
~UNDER CONSTRUCTiON~
- Rip_City_Spree
Re: LED lightbulbs
Johnny you been drinking?
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
Naraku sport variator
Currently 5g rollers
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
Re: LED lightbulbs
Hahaha that's awesome. I have no idea what happened there.Rip_City_Spree wrote:Johnny you been drinking?
Re: LED lightbulbs
"Polixles lasee"? Haha
Re: LED lightbulbs
It's cool, happens to me too. Pots legal here haha.
Re: LED lightbulbs
hi guys. Nice work on your LED headlights.
From your experiences do you know of a LED bulb or setup I can put on my spree? Something with low wattage. Just looking for a little better light/upgrade
Any advice would be greatly appreciated thank you.
Re: LED lightbulbs
I'm not sure if the spree uses he same headlamp as the Elite, but it looks like it. If that is the case , my recommendation is to purchase a headlamp housing for an '01 SA50. They cost avoit $35. It is physically the same size and mounts the same, but uses a replaceable bulb. I used that with a H4 Hi/Low led that I orucaes from eBay for $21. It will mount right into the housing and provides great light and low power consumption. It's a 30w Led , but uses much less current than an HID or halogen bulb. That's what my pictures are from.ped wrote:hi guys. Nice work on your LED headlights.
Re: LED lightbulbs
Thanks Johnny. The spree headlight is a sealed unit. But I think I can replace it with the elite.johnny248 wrote:I'm not sure if the spree uses he same headlamp as the Elite, but it looks like it. If that is the case , my recommendation is to purchase a headlamp housing for an '01 SA50. They cost avoit $35. It is physically the same size and mounts the same, but uses a replaceable bulb. I used that with a H4 Hi/Low led that I orucaes from eBay for $21. It will mount right into the housing and provides great light and low power consumption. It's a 30w Led , but uses much less current than an HID or halogen bulb. That's what my pictures are from.ped wrote:hi guys. Nice work on your LED headlights.
is the one with the ballasts? or without?
http://www.ebay.com/itm/H4-9003-LED-KIT ... DU&vxp=mtr
http://www.ebay.com/itm/261581922914?_t ... EBIDX%3AIT
Re: LED lightbulbs
Well, up until '01, the elite was a sealed units also. In '01, they took the same headlamp , but made it with a plastic lense and upgraded to a housing with replaceable bulb. It is the same dimensions, same mounting bracket, same everything as far as fit and installation. It is just much better because it has a reflector unit and lense that is designed for an H4 style bulb. So it looks the same, and fits the same, but you have unlimited bulb options, and better light output.ped wrote:Thanks Johnny. The spree headlight is a sealed unit. But I think I can replace it with the elite. Thanks for pointing me in the right direction for the bulb.johnny248 wrote:ped wrote:hi guys. Nice work on your LED headlights.
Like I said, I don't have a spree here, but looking at the headlamp from a Spree, it looks like the Elite headlamp would be compatible.
Here is a link the the lamp itself
http://www.partzilla.com/parts/search/H ... parts.html
This is the LED bulb that I bought. Works great.
http://www.ebay.com/itm/141455568329
Re: LED lightbulbs
Thanks guys for posting.
Re: LED lightbulbs
No problem. If you want an Elite headlamp to try out for firment, I have an extra stock one as well as a stock one modified with an HID bulb if you wanted to borrow one.
