'00 Elite SR Build
Re: '00 Elite SR Build
Here's mine w my washer/bracket/thingy I cobbled together holding it in.
Really? I thought everyone's was flush? It looks like it should drop in further. It isn't sealing at all sticking out like that.
2000 Elite SR
Malossi Cast, 24mm Polini (36/110), 9.8 gears, Naraku intake, PG long exhaust, 6k yellow Polini clutch springs, 5g roller weights. Top speed: 60mph
viewtopic.php?f=20&t=30550&hilit=pump+plug#p268867
viewtopic.php?f=4&t=27475&hilit=pump+pl ... 15#p239723
Meloshameless
So on the oil plug, it should sit flush. I found that out by removing the o rings and seeing how far down it wants to go. What i did was sand the bottom ring so it sat more flush and then i took the one off oil pump to use at the top, put some 2 stroke oil on it and punched it in with rubber mallet. If not flush u loose compression and risk air leak, idle problems and more...
2000 Honda SR (purple swurp)
corsa
naruku
polini vari 5.5 gram
zx trans
Yasuni C16
corsa
naruku
zx trans
Yasuni C16
I took the O-ring off and it'll actually go past flush, so the O-ring must just be a real slight touch too big I tried giving it a swift little tap with a hammer and it still won't go, may need some more force. Mine only has 1 O-ring.
- image.jpg (169.51 KiB) Viewed 10281 times
2000 Elite SR
Meloshameless
The last one i tried to shove in without sanding down it tore the bottom o-ring apart.
Use the o-ring from oil pump for the very top. Its the same as the oil pump used in the same spot. Makes semse.
corsa
naruku
zx trans
Yasuni C16
corsa
naruku
zx trans
Yasuni C16
Yup, I put that O-ring at the top, got it in snug, just need to make something to hold it down.
My new problem is getting the old reed cage out the dang gasket is so dried out it's stuck to the block, any suggestions on loosening up paper gaskets? Old plastic is chipping apart really easy so I have to be careful.
- image.jpg (156 KiB) Viewed 10279 times
2000 Elite SR
Meloshameless
I hope ur not trying to re- use that! Lol. Use a razor knife to score around the bottom where the gasket is. Multiple times if u have to. The use blade to scrape old gasket off. Ive pulled around 4 of those off. My best luck was rubber hammer taps and twisting hard.
corsa
naruku
zx trans
Yasuni C16
corsa
naruku
zx trans
Yasuni C16
Got the Malossi Cast buttoned up and Naraku intake, Polini carb set up on, still some little things to go.
- image.jpg (173.49 KiB) Viewed 10273 times
- image.jpg (178.61 KiB) Viewed 10273 times
2000 Elite SR
do you have any old plates from an car or bike laying around? cut an corner off and use that to hold your oil plug in, I saw a guy do that on totalrukus...
2021 DRZ400sm
2021 DRZ400sm
Got this PG Long mounted up, I think I got lucky from what I heard, was expecting it to not fit well. It fit perfect! Score! Tomorrow I'll put the finishing touches together, cap the oil plug, mix up some gas and start it for the first time.
- image.jpg (171.06 KiB) Viewed 10268 times
2000 Elite SR
You shouldn't be cross-training like that son. You could get seriously injured!MrJumps wrote:do you have any old plates from an car or bike laying around? cut an corner off and use that to hold your oil plug in, I saw a guy do that on totalrukus...
Got the oil plug in and sealed off with a big fender washer.
- image.jpg (177.01 KiB) Viewed 10472 times
2000 Elite SR
Got everything put back together and started up first kick! Thanks to G9 for the parts, wow the power is great compared to stuck! Not even done breaking in yet, so it'll be a while until I feel ready to open her up. I'm running a 108 main and 45 pilot, possible a little rich? I will figure that out once break in is done, I'll lean it out some if need be. Mainly I think the pilot jet is a little too rich. Looks like a lot of guys run 35-40 on the pilot of these Polinis.
2000 Elite SR
