Old broken clutch:
New clutch:
Side by side. You can't see it here, but the new clutch had a bit more meat on the pad, and the pad itself was longer. You CAN see the clutch bell is dotted (for ventilation?) and the big oval holes in the top of the bell are like little scoops instead of just flat round holes. It also came with a 1500rpm torque spring and 1500rpm clutch springs already installed:
Also ordered jets 85, 90, 95, and 100. The 90 that came with it didn't seem like enough after the mods. The homemade 100 seems to run a bit to rich. Gonna try out the 95:
