Problem installing BBK
Re: Problem installing BBK
W/o at least new roller weights and maybe a new vario you won't have any takeoff w gears I think... trust me, if your just looking for around town performance then put the tallest tire on the rear you can find and pump it up to 40 psi, then get a clutch n vario n belt. Way worth it, even if you go kinda cheap. You can use a new ramp plate and rollers w your stock vario and buy new stiffer clutch springs for your stock clutch, that would help too.
FunkeyMonkey
Springs and rollers are defiantly doable. Right now the scoot has amazing pickup, I keep up with or pass most cars til I hit 30 then I'm left behind, partly because I'm still taking it easy for break in and not wanting to WOT it. For gears should I be looking at 9:1 or 8 something?
2001 Honda Elite 50
72cc malossi cylinder
24mm polini carb
Naraku intake
24mm polini carb
Naraku intake
Up to you, I haven't done gears on mine yet so I don't kno what power band these gears put you into but I'd go shorter if possible. Like 9 to 1, that way you'll get some top speed but you shouldn't lose too much down low.
