My 1994 Honda Elite
Dallen70
Re: My 1994 Honda Elite
Post by Dallen70 »
You have to play around with the rollers you put in there. Typically you get more top end with heavier rollers and more acceleration with lighter ones. I run 5.5 g in mine and I'm still messing with it. Just something you have to get dialed in. I would also grab a set of gears from SSS, the 9:1 or even 8.44 gears are a great combo with the vari. Most people do that when they are just getting their feet wet into performance mods. You should see high 40s, low 50s on gears and a variator with the right tune.
ansneds
Post by ansneds »
Will an aftermarket air intake increase performance? Also are aftermarket CDIs good for a stock build?
Currently own:
->1995 Honda Elite 50 (Derestricted)
Have previously owned:
->Multiple 94-01 Elite 50s
->1985 and 1986 Honda Sprees
->1985 Honda Aero 50
Xxbeejay45xx
Post by Xxbeejay45xx »
Air intake will need to be rejetted and you don't need a aftermarket Cdi but if you choose to get one... Malossi is the one I have
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
Polini vari, clutch, springs
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Front and Rear disc brakes
Dio Live headset
Stretch and fatty rear wheel
ansneds
Post by ansneds »
Decided to get a GPS app to see what my top end actually is since I can't tell on the speedometer. Is this pretty good for the stuff I've done to my elite?
Currently own:
ansneds
Post by ansneds »
Made a video showing my top speed. I know it's not as fast as other builds, but it's a lot faster than stock!
https://www.youtube.com/watch?v=OGuK9bAFJkE
Currently own:
ansneds
Post by ansneds »
Made another quick video showing what the PG Short exhaust is like on an elite for people interested.
https://www.youtube.com/watch?v=smi1_QngeOw
Currently own:
ansneds
Post by ansneds »
Got the 15x42 (9:8:1) gears installed today. Noticed a decrease in acceleration which I expected. Top end was pretty good. Still have to check the gps, but the needle seemed to go farther than usual!
Currently own:
ped
Post by ped »
ansneds wrote:Got the 15x42 (9:8:1) gears installed today. Noticed a decrease in acceleration which I expected. Top end was pretty good. Still have to check the gps, but the needle seemed to go farther than usual!
Dude, sounds like you need to up jet.
ansneds
Post by ansneds »
I think I do, still running 78 main. What would you recommend going up to?
Currently own:
ansneds
Post by ansneds »
Big thanks to bfowler for the tail light and turn signal lenses!
Currently own:
