54mm build/ nuts packed in box
ped
Re: 54mm build/ nuts packed in box
Post by ped »
:coolcruise:
This is the best build to come along in a looong time. Looks great, ped! :2thumbs: :popcorn:
ped
Post by ped »
Meatball wrote:This is the best build to come along in a looong time. Looks great, ped! :2thumbs: :popcorn:
Thanks meatball it's coming together. The reason you don't see many build's it's because everyone's riding. Hehe. :smile:
ped
Post by ped »
:coolcruise:
ped
Post by ped »
:coolcruise:
ped
Post by ped »
:coolcruise:
:rock: :popcorn:
HI808SYM
Post by HI808SYM »
there are special "slim" crankshaft bearings that are used with this crank.
if you use the stock bearings the case will not close and seal together.
i have slim bearings for sale if you need a set.
lmk
btw nice build very meticulous very nice
wwolvert
Re: 54mm / nuts packed in box
Post by wwolvert »
ped wrote::coolcruise:
Where did you get that cutting tool?
Revolutionary
Post by Revolutionary »
Cool build!
ped
Post by ped »
HI808SYM wrote:there are special "slim" crankshaft bearings that are used with this crank.
lmk
Thanks. The Kit came with the bearings. :thumbwink:
ped
Post by ped »
http://www.ebay.com/itm/Honda-Dio-Elite ... SwSlBYucVt
Hi, I bought the tool on eBay. It's very hard to work with this tool. You have to take off very light cuts. You also have to use a Dremel to finish. There is some skill involved. I recommend a machine shop. The tolerance are too close and easy to screw up. Also it's not easy to cut the top of case for the Big Bore cylinder. Good luck :coolcruise:
ped
Post by ped »
Revolutionary wrote:Cool build!
Thanks Rev.
:peace:
ped
Post by ped »
Hi Forum. The water cooled motor is on hold. I'll add the air cool photos, which is the same 54mm build.
:coolcruise:
ped
Post by ped »
:coolcruise:
