Page 3 of 6
Re: 54mm build/ nuts packed in box
Posted: Thu Aug 10, 2017 4:18 am
by ped
Posted: Thu Aug 10, 2017 10:31 am
by Meatball
This is the best build to come along in a looong time. Looks great, ped!
Posted: Fri Aug 11, 2017 1:40 pm
by ped
Meatball wrote:This is the best build to come along in a looong time. Looks great, ped!
Thanks meatball it's coming together. The reason you don't see many build's it's because everyone's riding. Hehe.
Posted: Fri Aug 11, 2017 8:19 pm
by ped
Posted: Sat Aug 19, 2017 4:29 am
by ped
Posted: Sat Aug 19, 2017 4:33 am
by ped
Posted: Sat Aug 19, 2017 11:43 am
by Meatball
Posted: Sat Aug 19, 2017 5:31 pm
by HI808SYM
there are special "slim" crankshaft bearings that are used with this crank.
if you use the stock bearings the case will not close and seal together.
i have slim bearings for sale if you need a set.
lmk
btw nice build very meticulous very nice
Re: 54mm / nuts packed in box
Posted: Sat Aug 19, 2017 6:10 pm
by wwolvert
ped wrote:
Where did you get that cutting tool?
Posted: Mon Aug 21, 2017 11:02 pm
by Revolutionary
Cool build!
Posted: Wed Aug 23, 2017 4:12 am
by ped
HI808SYM wrote:there are special "slim" crankshaft bearings that are used with this crank.
lmk
Thanks. The Kit came with the bearings.
Posted: Wed Aug 23, 2017 4:20 am
by ped
http://www.ebay.com/itm/Honda-Dio-Elite ... SwSlBYucVt
Hi, I bought the tool on eBay. It's very hard to work with this tool. You have to take off very light cuts. You also have to use a Dremel to finish. There is some skill involved. I recommend a machine shop. The tolerance are too close and easy to screw up. Also it's not easy to cut the top of case for the Big Bore cylinder. Good luck
Posted: Wed Aug 23, 2017 4:29 am
by ped
Revolutionary wrote:Cool build!
Thanks Rev.
Posted: Thu Aug 31, 2017 1:34 am
by ped
Hi Forum. The water cooled motor is on hold. I'll add the air cool photos, which is the same 54mm build.
Posted: Thu Aug 31, 2017 1:37 am
by ped
