Ive been tempted to order a polini from the fatherland for the wifes aeroharleyracer59 wrote: Mon Jan 27, 2020 10:44 pm so to date ive purchased and ran a polini iron cylinder, metrakit iron, pinasco iron \, zeda racing iron, italkit aluminum.
the polini kit is a torquey upgrade over stock. not the fastest or most rpm but its a reliable tough cylinder with easily obtainable replace ment parts. will work with 1 base gasket but liked 2 base gaskets a lot better. was faster more torque and gained 400 rpm has a top rpm of 8900-9400 depending on carb size and exhaust pipe selection. iit can be ran hard and keep going.
ill add more on the other cylinders as I get time
opinions on best variated AF05e big bore kit
- nateberrier
Re: opinions on best variated AF05e big bore kit
1986 Aero White -- Stock With Keli Var
1985 Aero Red -- Af05 Malossi BBK + Keli Var
1985 Aero Red -- Af16 Corsa / Fabrizi Pipe / Polini 24 PWK / Athena Stuffer Crank
- harleyracer59
the metrakit and the zeta racing kits are my favorite kits so far. the polini is a good kit but the 9800 rpm is a bummer. and that's after 2 gaskets. I might try to raise the exhaust a mm when I get some time and see if that helps anything. I also want to put a 90/90 on it cause currenyly I only have a 3.00 rear
