2001 honda elite s (dio) Stroker 100cc on spree
mercedesboy
Post by mercedesboy »
[quote="diosoljah"]I live in hawaii and and theres a multitude of shops that modify mopeds mainly the 1994-2001 Honda Elite S which has a dio motor and Jog. As for my Honda Spree, The Entire block is a 2001 honda Elite S motor (Dio) Keep in mind that honda released this motor from 94-2001 and is the most sought after motor to modify here. After Stroking the motor (51mm cylinder, 51mm stroke=104.22679 CCs) and porting block (intake and boostport) porting the cylinder (Exhaust, and transfer port) Greatly improved Mids and High end but from this point the low end was sacrificed and to improve the low end Ive jetted down on the pilot jet and decreased the weights in the high speed pulley, ive put a centerspring bearing to stiffen out the 1500 centerspring to a 1800, increased spark by installing a racing coil and racing cdi by doin all this it reved higher to improve the low end. and as for top speed 100mph plus
heres the shops (These shops are located in Honolulu, Hawaii):
KS Cycles (This is a new shop, try calling honolulu local operator for number)
Botek Mopeds (808) 943-1868
VT Cycles (808) 593-7733 (1251 S. Beretania St. Honolulu, HI. 96814)
Call for Keoni or Steve
Quik Fix Cycles (808) 536-2277 (725 Auahi Street Honolulu, HI 96813)
Call for Frank (Owner)
Cycle Imports (808) 952-9253 (847 Mccully St, Honolulu, HI 96826)
Call for George (Owner)
Glenns Cycle (808) 732-5547 (3703 Waialae Ave, Honolulu, HI 96816)[/quote]
someitmes u jus wanna go somewhere nobody know u. den u can be da legend for once. :roll:
REGULATORS WORLDWIDE!
hrnytrtlsgsxr
Post by hrnytrtlsgsxr »
lonelywanderer wrote:
vette76 wrote:and i kill tha mood now.lol stock. low on $$ u know. all i gotz a speed pulley.
just deristricted with a hi speed pulley is good enough for just riding around.... fast enough for alot of people
if you need high performance parts. vt cycles is one place. add the www and .com to order on line.
sulfuraciddd
Post by sulfuraciddd »
supzah i stay here
85stroka
Post by 85stroka »
OOOPS!!
mercedesboy
[quote="sulfuraciddd"]supzah i stay here[/quote]
den we can all leave
he he
85stroka
Post by 85stroka »
[quote="mercedesboy"][quote="diosoljah"]I live in hawaii and and theres a multitude of shops that modify mopeds mainly the 1994-2001 Honda Elite S which has a dio motor and Jog. As for my Honda Spree, The Entire block is a 2001 honda Elite S motor (Dio) Keep in mind that honda released this motor from 94-2001 and is the most sought after motor to modify here. After Stroking the motor (51mm cylinder, 51mm stroke=104.22679 CCs) and porting block (intake and boostport) porting the cylinder (Exhaust, and transfer port) Greatly improved Mids and High end but from this point the low end was sacrificed and to improve the low end Ive jetted down on the pilot jet and decreased the weights in the high speed pulley, ive put a centerspring bearing to stiffen out the 1500 centerspring to a 1800, increased spark by installing a racing coil and racing cdi by doin all this it reved higher to improve the low end. and as for top speed 100mph plus
someitmes u jus wanna go somewhere nobody know u. den u can be da legend for once. :roll:[/quote]
is this WWE ? 8O
mercedesboy
[quote="85stroka"][quote="mercedesboy"][quote="diosoljah"]I live in hawaii and and theres a multitude of shops that modify mopeds mainly the 1994-2001 Honda Elite S which has a dio motor and Jog. As for my Honda Spree, The Entire block is a 2001 honda Elite S motor (Dio) Keep in mind that honda released this motor from 94-2001 and is the most sought after motor to modify here. After Stroking the motor (51mm cylinder, 51mm stroke=104.22679 CCs) and porting block (intake and boostport) porting the cylinder (Exhaust, and transfer port) Greatly improved Mids and High end but from this point the low end was sacrificed and to improve the low end Ive jetted down on the pilot jet and decreased the weights in the high speed pulley, ive put a centerspring bearing to stiffen out the 1500 centerspring to a 1800, increased spark by installing a racing coil and racing cdi by doin all this it reved higher to improve the low end. and as for top speed 100mph plus
DAMM SHUT THE F DOWN ![/quote]
no swearing allowed in this family oriented forum. thankyou, Admin Regulator
85stroka
Post by 85stroka »
:D that's why I never type em out
mercedesboy
[quote="85stroka"]:D that's why I never type em out[/quote]
type dis n tap dis *
wher u at boy?
85stroka
Post by 85stroka »
it's o3 xrs from fh, I edit em I no like start to much S -we all new here.
mercedesboy
[quote="85stroka"]it's o3 xrs from fh, I edit em I no like start to much S -we all new here.[/quote]
oh, sorry bo$$ xrs.
many people mistake me for somebody that gives a f**
85stroka
Post by 85stroka »
:D
sulfuraciddd
ohh thats you. dam you guys getiing me all mixed up
mercedesboy
[quote="sulfuraciddd"]ohh thats you. dam you guys getiing me all mixed up[/quote]
das yo name BO$$ Sir Mixalot. all give propz
85stroka
Post by 85stroka »
:D
Locked
