Words from the wise?
- BMX
- BMX
umm, you mean, you cant idle?
like when you stop the bike dies?
or are you saying the clutch is not disengaging? What happens there is the motor keeps turning since the wheel is turning. Using the brakes forces the motor to go slower. When you stop it dies.
please explain your question better.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
- BMX
forgive me, yes, by braking, the engine slowly dies down....or even by not accelertating...as it slows down the engine will cut out around 10, 5 mph.
Also, the threads on the carb are shredded, i bolted everything together, yesterday morning, using the new bolts i ordered. On the way home from work, with the vibration, the bolt just fell out, I was not able to recover it concidering i lost it on a busy street, and it was dark....any suggestions? i pray I dont have to buy a new carb.
- BMX
- BMX
- BMX
- BMX
forgive me, I havent been wording my posts correctly, im just really frustrated. THe carb itself is fine, works perfectly. I just cant get the air cleaner to mount to it and seal it....first i was running with one bolt...then i ordered the new ones which fell out on a ride home, i tried using nuts and spacers to get it to seal, nothing seems to be working.
- BMX
pictures say 1000 words......and since i cant find the right ones....
here is an overall look of the area im tryin to speak of...
this is a picture of the problem itself...
I can turn the bolt as much as i'd like too....but it will not tighten if my life depended on it... (i realize that bolt is too long, but the new ones i ordered i lost on a ride home...the vibration cause them to come off and i was not able to recover them)
i tried bolts and nuts on the other side which also wont tighten, and i tried...
....to stack washers to get more of the bolt in the carb...i had a spacer which was too tall, not allowing much of the bolt to grab the carb...i though this would do the trick.....but no...
- CharlotteSpreeRider
