Nos on a moped
Post by Kenny_McCormic »
noiseguy wrote:Anyone thought of making a ghetto-style NOS setup using an airbrush full of gasoline pushed through by NOS?
That aint a bad idea.
It would certainly be cheaper than $600.
fireblade
Post by fireblade »
To use a wet kit on a scoot, you'd need to run a fuel pump. Plus the current draw for the soleniods. How many amp is a spree charging system? I have a couple of nitrous kits, but I dont want to destroy my engine. and I think it might be a strech to fit a 10lb bottle on a scoot.
HONDA NQ50 "FIREBLADE"
fireblade wrote:To use a wet kit on a scoot, you'd need to run a fuel pump. Plus the current draw for the soleniods. How many amp is a spree charging system? I have a couple of nitrous kits, but I dont want to destroy my engine. and I think it might be a strech to fit a 10lb bottle on a scoot.
Its enough to run it for the 4 or 5 seconds it gets used every hour, you can get 10oz units, holly made a special kit for gopeds that came with a 10oz and an RC battery pack connector.
Dac
Post by Dac »
CONGRATS KENNY!
You have got 1337 Posts!
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
I am t34 1337 *!
michaelg
Post by michaelg »
Dac
Post by Dac »
This is just a hint of whats to come. Ill let MopedMan post pictures himself when he says its done.
Wouldnt you want the bottle angled up so it only gets gas instead of liquid?
Dac
Post by Dac »
Kenny_McCormic wrote:Wouldnt you want the bottle angled up so it only gets gas instead of liquid?
:shock: :lol:
98Park
Post by 98Park »
no, you want it with valve up and the label out so the siphon tube gets to the bottom. the goal is to draw liquid with as little gas as possible. the gas is what gets purged out before spraying, if you've ever sprayed without purging or with the bottle disoriented you can feel it chug out when it runs out of liquid nitrous
whats with corsica's and dragging nitrous lines?
Ahh, with my limited experience around liquid gases siphons, and long hoses dont mix guess NOS is a lil different.
DorkoElite303
Post by DorkoElite303 »
Couldn't you use a "T" fitting on the fuel line and still use a wet set-up? I know our scoots don't have a fuel pump. But I figure the shot of the nos would cause a sucking or vacuum on the fuel line and pull fuel out with the shot?
maddog
Post by maddog »
NOS is not meant for 2 stroke engines, i am still waiting to see the michigan boys build a true full stroker, its the parts you can't get- i can :lol:
Dac
Post by Dac »
maddog wrote:NOS is not meant for 2 stroke engines, i am still waiting to see the michigan boys build a true full stroker, its the parts you can't get- i can :lol:
we can get the parts also, there is such thing as "shipping" you should read about it. :wink:
