What is your top MPH?
MySpree
Post by MySpree »
76mph
justinnielsen01
Post by justinnielsen01 »
MySpree wrote:76mph
on what
Post by Kenny_McCormic »
nparks wrote:
Kenny_McCormic wrote:
nparks wrote:~60mph... then the engine seized. =(
Did you try freeing it with PB like I told you?
Haha yeah I did, but it was nearly impossible. It definitely helped though! Without PB I'd still be clueless as to how I'd get the d*** piston off of the crank.
sometimes the damage isnt too bad and you can run it as is.
burnt_toast
Post by burnt_toast »
MySpree wrote:76mph
bs flag ya poser.. :roll:
projects galore :nerd:
cf_z
Post by cf_z »
well.
125
mazda mx6 v6 turbo ;)
hopefully i'll be able to post an actual moped speed this week
94 Elite SR.
PoliniCorsa+PGlong+28oko+8.44.1+KeliVariator+HiEnergyCoil+Pirrelis
=fast
GN Racer
Post by GN Racer »
'85 Aero w/'87 Elite engine 62cc Proma bore & chamber exhaust, Kitaco manifold w/18mm Mikuni carb, Daytona high speed pulley, 8.5? : 1 gears.
Was doing 50+, but now it's not. Currently doing only around 48 MPH.. :( It's been sitting for years now, so it looks like I'll need to do some maintenance... :roll:
'87 Spree w/'94 Dio engine ported Malossi 72cc, Proma chamber exhaust, 28mm Keihin flat slide carb, Daytona high speed pulley, ZX trans, Daytona clutch springs & center spring, 6.475:1 gears.
50++ MPH. Fast enough for me. Absolutely no idea what the top speed is... :lol:
Geoff
'85 Aero 50 w/Dio 66cc
'87 Elite 50 w/Dio 72cc
'87 Spree -SOLD!
Puch Magnum
Yamaha Razz POS -Soon to be Dio powered!
keithw
Post by keithw »
I'm trying to see how fast I can get my Pal (JDM Spree) to go with the original motor. If I put a Dio motor in it then it's not a Pal with a Dio motor, it's a Dio with a Pal body. From what I've seen and done so far I don't think the Spree/Pal will do much over 60 mph on level ground, if it will get that fast. The big limitation is the gearing. The motor just isn't going to be good for much over 11k rpm and there is only so much you can do with the Pal/Spree trans. My goal is 100 kph (62 mph). There are lots of 50cc scooters that will do that but the Pal/Spree was built from the ground up to do 25 or 30 mph so it's a bit of a stretch. Even with nitrous you still have the problem of how fast the motor will turn around and stay in one piece.
So far I'm up to 45 mph. The current project is porting the cylinder and possibly 55cc big bore, if I can round up the piston to do it.
keithw
Honda Spree, 1985.
Another Honda Pal
stevesearles
Speed
Post by stevesearles »
2000 Elite S: Got it going 40 mph with the exhaust opened up near the cylinder and removing the clutch varator limiter. Highly recommended. I then bought a throttle cable that has the oil pump cable on it. Run synthetic oil and 38-40 mph! Cool. I started at 25 mph. Bumming, it is starting hard after it sits for a few days though. What's up?????
DorkoElite303
Post by DorkoElite303 »
nparks wrote:
Obviously not good enough. I put just under 100 miles on it and decided to see what it'd top out at and as soon as I hit 60 it popped.
AHHHHHHH!!!! BAD ELITE RIDER! BAD!
What did you use for the pre-mix???
keithw
Re: Speed
Post by keithw »
stevesearles wrote:2000 Elite S: Got it going 40 mph with the exhaust opened up near the cylinder and removing the clutch varator limiter. Highly recommended. I then bought a throttle cable that has the oil pump cable on it. Run synthetic oil and 38-40 mph! Cool. I started at 25 mph. Bumming, it is starting hard after it sits for a few days though. What's up?????
Before you start it after a few days open the carb drain valve. If nothing or very little comes out then the carb is simply dry. Mine has started doing this since the temps started getting into the 100s.
keithw
Honda Spree, 1985.
Another Honda Pal
wikked_spree57
Post by wikked_spree57 »
1986 Honda Spree brought back from the dead - I found it sitting in this guys yard driving by and he said it had been there quite awhile.
Now since I repaired the top end I'm hitting 35-37 on level ground thanks to police radar and being pulled over for the brake light being out :)
The best Spree I've had yet.
1983 Yamaha XC 180 - Bought barn fresh in mint condition and 254 miles. Best bike I ever owned :)
burnt_toast
cf_z wrote:well.
125
What.. thats it?!? seems low out of a turbo..
I've topped my v6 N/A Dodge Avenger with only slight mods at 128mph, but if you don't have the room to play with I don't blame you, topping out a car isn't the smartest thing to do anyway lol
cf_z
Post by cf_z »
burnt_toast wrote:
cf_z wrote:well.
125
stock clutch.
and i didnt like the smell too much ;)
plus i wasnt exactly on a "suitable" road to be doing those speeds.
im sure with a new clutch, and a good road, it would do 145.
94 Elite SR.
=fast
nparks
Post by nparks »
Pre-mix... what's that? ahaha
I'm just messing with you. I was using 50:1, but this tank I didn't have it on me and I figured the stock pump would do it's job enough to let me go 60 for a little less than a minute.
burnt_toast
cf_z wrote:
burnt_toast wrote:
cf_z wrote:well.
125
stock clutch.
yeah i believe it mann, stay safe and dont try it lol :twisted:
