I'll try to answer what I can:
Hm, I haven't checked the compression yet, no. I'm honestly pretty new to fixing up things like this, I've been kind of learning as I go. How difficult it would it be to check the compression, would I need some fancy equipment to do so?
Actually this is one of the simplest, quickest, and cheapest things to test:
http://www.harborfreight.com/cpi/ctaf/d ... mber=92697
And my idle screw's about... 3/4ths of the way in?
First you need to be aware that there's an Idle Throttle Stop screw, which is basically a doorstop for the throttle slide, and an Idle Mixture screw, which adds air to the incoming mixture as you screw it out from fully seated. Most people turn it in lightly all the way until it stops, then measure by half-turns out from there. A turn and a half is typical. Once the engine is fully warmed, you adjust to get the highest idle speed after the throttle-stop is set to roughly 1800 RPM.
Do you mean the needle clip position? What makes you believe it's a bit lean? The needle clip setting richens or leans the midrange, part-throttle mixture only. Clip on top is leanest. Clip at bottom-most is richest. Start in the middle - my needles have all had only 3 grooves, but some have 5.And the jet's set to the 4th setting, it's running a bit lean.
Bingo!Here's how it currently runs... yadda, yadda, yadda...
So, any ideas? yadda yadda... it feels like the carb just isn't getting enough fuel to it from the start.
I think your bike needs a working cold-start mechanism which this carb is not providing. If no one with the knowledge of this exotic carb to help you make it work comes forward, I like the idea of replacing it with a proper US-marked mixer with a bystarter. Many of us know all about that device.
See above. Fuel's in the carb, but a cold engine needs much richer mixture until it warms.But when it's running from the manually added fuel, the throttle starts responding, meaning fuel is getting to the carb just fine. Is there not enough suction from the vacuum tube to the petcock from a cold start?
I only use my plumbed primer if the bike's been sitting more than a few days.I've seen a few people mentioning adding primers - could this be a viable solution? And sorry if any of this sounds obvious or elementary - again, I'm pretty new to stuff like this.
HTH
