I honestly don't remember what's in my own OKO 26, but I need to check. It was pretty responsive in the cold weather, but feeling richer as Deepinnaharta warms up. Mainly I wanted this to be post #300 in your thread...
Checkin in, first post... here at least
Re: Checkin in, first post... here at least
Chicago Ben
300! woo
Assuming that this UNI is going to act as if there were no air filter on at all (very little restriction)
I think either 50-55 pilot and 120-125 main will work fine. Still having these flooding over bump issues which is a float height adjustment.
I just want to ride this and not worry about tuning anymore!!! never ending...
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
1000k Polini triples
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Chicago Ben
I found a 52 pilot in my parts bin.
Swapped that into the carb tonight-
we'll see what happens when this Uni filter shows up this week
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Chicago Ben
patiently waiting an UNI 4200 filter...
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
I'm in the same boat, i thought i was done till i went to put the filter onChicago Ben wrote:patiently waiting an UNI 4200 filter...
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
- Trafficjamz
are you 100% sure about the bump issue being the float height?
If it does not go completely dead it could be the float, not necesisarily the wrong height but since the carb is held on by the rubber to the ct manifold it has no other support so it moves up and down when you hits bumps causing it to run rich at the moment you hit a bump. What I do when i see a bump is I slow down then gas it right as i roll over the bump
otherwise it sounds all bubbly
Chicago Ben
About 90 % sure. When I hit a bump that I didn't see I have to gas it back again (takes a couple seconds) . I'm going to attempt to adjust the floats so my bowl fill height is about 80-90% of where it currently fills to. Wish adjusting the floats on these carbs wasn't such a guessing game.Trafficjamz wrote:are you 100% sure about the bump issue being the float height?
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Chicago Ben
now all I have to do is wait for my friend to drop the moped back off at my place... until next week...
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
