PLEASE HELP! Resurrecting 1987 SE50P Elite and derestriction
Re: PLEASE HELP! Resurrecting 1987 SE50P Elite and derestriction
Martykim,
Did you leave the brass plate off of your variator? I'm thinking about doing the same... You haven't had any issues with that, right?
Also, what rollers did you use?
Keep it off.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
- martynkim
I have a Keli variator without a back plate. The rollers I used came with it I don't know the weight. And It runs just fine.
I think the Keli comes with 9's
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
8.7gevilone wrote:I think the Keli comes with 9's
Then I, too, shall use the rollers that came with Keli variator, lol. I will discard the irridited tin piece as well. Thanks!
- martynkim
The OKO from VT Cycles is cheaper and performs just as well.
- martynkim
Re: PLEASE HELP!!!! [Resurrecting 1987 SE50 Elite -Ed.]
Saved up and following advice now.Wheelman-111 wrote:Greetings:
'85 and later Aero shares almost all major engine components with your SE. That pipe should fit fine.
If you can afford/save up for a LeoVince exhaust you will not be disappointed.
I didn't have good luck with the OKO variator. I don't remember where I bought mine, but it wasn't VT Cycles. Perhaps there's more than one version? The one I had didn't feature dowels protruding from the casting as far as the Keli. Its diameter was a bit smaller too. Ramp profile wasn't a good match for 65cc Flash I, and top speed was down a couple compared to the Keli. However the OKO ramp plate on the Keli bested the stock ramp plate by far. Nothing I've used worked as well as the AF Polini, and the 94mm Polini for Ruckus is even better, once some room is carved out for it.
- martynkim
I do have a spare OKO ramp.
I didn't like my oko either.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Good to know, but I purchased the Keli variator from daywot last year -- just haven't put it in yet.
- Trafficjamz
http://cgi.ebay.com/ebaymotors/Variator ... 9107261408
This roller tuning pack comes with the variator and ramp plate!
I like it alot, and I have a keli vari too. , and cant tell the difference between to two.
- martynkim
Get on thatgixxer9 wrote:Good to know, but I purchased the Keli variator from daywot last year -- just haven't put it in yet.
Lol! I'm waiting on a few more parts, including the ramp guides and such.... I should have everything in a week or so.martynkim wrote: Get on that
