Official NS50F thread
z50r-ghost
Post by z50r-ghost »
-Ok doods;
i guess i will let my new pics (that are waay too dark - "6 p.m. pics") speak for themselves, then i will post the long list of mods tomorrow! My NS50F is getting close to being completed! -Better pics soon.
please let me know what you think... :love:
Special RK chain, new HRC rear caliper / rear master cyl, and floating front rotor on the way...
later guys - j.
>< Solitaire Unraveling ><
...my life story
1990HONDANS50F
z50r-ghost
:?: -can anyone spot the very special part I added to my NS's engine that is a big "power adder?"- :?:
-you *really* have to look for it. It's not the VForce reeds, Posh fuel valve, or air funnel...
-talk to you guys later, j.
:mrgreen:
...my life story
1990HONDANS50F
lowburb
Post by lowburb »
Yay!!! Beautiful bike!! It looks great! Thanks for the pictures!
sanjuro
Post by sanjuro »
Absolutely inspiring build!!! That pipe looks amazing, just like the rest of the meticulous build.
KingJeff801
Post by KingJeff801 »
HOLY s***.....Bad *!!!!!!!!!!! great job, straight off the performance showroom floor!
KJ
2001 Elite S
72cc Corsa
24mm OKO
Scorpion Pipe
Pic and Vid post
Gun Post
Wrong Side Kings 4 Life
Red Eft Performance
Post by Red Eft Performance »
very nice ghost!
Red Eft Performance
View products click => Here
veedubh20
Post by veedubh20 »
awesome! clean from just off the honda factory!!! :surprise: :mrgreen:
motomech
Post by motomech »
Ghost, very nice. Looking very much like the big wheel I raced.
I had mentioned earlier two of the "milestones" during development, the pipe and the frt. disc brk. and your pics recall them to me.
Also, as I mentioned, my pipe was Hyrdo-formed by a fellow racer. The funny thing is, when I asked him to build me one, I half expected him to ask me all sorts of stuff, like bore and stroke, carb size, etc, and to get out a tape measure and start going over the bike. He did none of those things and simply told me he would have it the next race.
When it showed up, i was surprised. I had expected it to be a "fatty" pipe, as was the trend back then with the MX bikes. But no, it looked pretty much the same as the YSR pipes[and the one installed on your bike]. How he made it to fit my NS perfectly[which it did], I have no idea.
I remember well how the frt brk. came about.
I was fortunate enough to be sponsored by Star Cycle in Tucson, an independent shop with one of the largest MC boneyards in the US. I went with a late '80's YZ80 system as it was small and powerful and the machinist at Star[Thanks again Jimmy]only had to make a bracket to mount it on the NS fork leg. But the rotor was another story. I rummaged and rooted though boxes after work for a week and nothing was even close. Finally, just when I was ready to give up, I stumbled on a disc from a '70's Honda CB200. It was a rare set-up from Honda, a mechanical disc brk. system that in all fairness, didn't work well on the heavy street bike. But a disc is a disc and it bolted up to the NS hub and was the right radius. I was very lucky on that one and on the track, it had plenty of power. I would have called it a "two-finger" brake.
The tires I ended up using were much smaller though. I'm not sure, but I think the Michelin RS125 frt slick was something like a 85/65-17 :roll:
Back to the engine-I have already mentioned the connection I had found between the NS 50 engine and the air-cooled CR80's of the mid '80's, but at that point, I didn't have a piston. So I got a Weisco cat. and started pouring over piston dimensions, specificlly bore size, piston pin size and location. When I got to the KX 60 piston, it jumped off the page! A perfect replacement. Same installed height! Huge! No need to remove material from the top of the cyl. And while it only increased the displacement by 8cc's[49 to 57cc], it was slightly domed, but best of all, it was an ART piston :woot:
I guess a little back-round is appropriate here, to explain what an ART piston is and why it was so important to me.
ART, is an acronym for a huge Japanese manufacturing Co. that makes all O.E.M. pistons for the Japanese Big Four{or at least they did in 1990].
Why that was important can best be summed up by a common pseudonym of the day we used for Weisco, we called them Seizcos. In 1990, nobody could make a piston of the quality of the Japanese O.E.M. pieces and the thermal expansion of aftermarket pistons required fitting them "loose" in the bore. One only had to hear a Weisco equipped 2-stroke to know what was in there. They rattled.
Boring out the NS cyl. several milimeters presented no problems, but great care was taken with the fitment. Since the engine was liquid-cooled and I was using an O.E.M. piston, piston to cyl. clearance was a very tight .001" to .0015". It was installed, run though a heat/cooling cycle two times, sanding down any high spots on the piston skirt both times before the engine before "break-in" was even started. It was this top end that was used for several seasons[over 40 races and practice and even an ocassional endurance race]with nothing more than replacing the ringsonce every off-season. As I recall, I used the standard NS small end bearing. Simply amazing reliability and longevity.
The KX 60 piston also had a lot to do with the direction I ended up going, and in this, I primarily mean the cyl. porting.
So I am looking at the cyl, wondering what I'm going to do and I take review of what I have.
I have CR80 ign., transmission and intake system and what is starting to look like a KX 60 top end, well, at that point it didn't take much brains go ahead and "turn" the NS into a KX 60. After all, there are worst engines a mini racer could end up with, the KX 60 was a well known rocket and some of the smaller MX riders were racing them in the 80cc class.
I was able to get a hold of a port/area map for a KX 60 and I scalled it up to NS cyl size, overlayed it on tracing paper and scribed onto the NS cly. I never took notes, but I remember it was nothing too radical. The transfers were widened a m/m or two, as was the intake and the exh. was raised probably several m/m's and opened up as much as possible. Finishing touches were techniques I had been taught during my RD modd'ing days. The exh. was polished, but everything else was left rough. Special attention was payed to the transfer "roofs"[or floors, depending on one's perspective]. They were carefully shaped to almost a 90%. Once enough time was on the motor, the head was removed to check the pattern of the Schurle loop etched in carbon on the piston crown[it was very good from Honda]. There was no cc'ing of the transfers nor "matching" to the cases, such as was my confindence in Honda quality.
The rest of the aux. components were pretty much standard, standard NGK plug, Boysen two-stage reeds and Bel-Rey MC-1 mixed with a 50%/50% mix of Trick Racing and pump gas.
At the time[and even now as far as I know], there were only two accessories offered by Honda for the NS, the Fairing and the mechanical tach. and I bought them both. The fairing turned out to be too heavy and I replaced it with an universal clubman piece that looked like this;
The tach I kept, but it couldn't keep up with the engine and there was no time to look at it anyhow. I do remember that I could bury it[15,000 rpm]on a long straight].
One thing that bothers me is that for the life of me, I can't remember which wheels I used. I'm assuming the stock ones, as I don't remember lacing up any special wheels. That, plus I do remember the bike always had a drum brake on the rear. It was all that was needed for racing, as the rear brake is used more for "loading" the chasis than actually stopping.
Above, I touched upon the weight of the optional fairing, but the whole bike was heavy by todays standards, but then again, YSR's are heavy too.
It was only later, as a small wheel, using the beautiful aftermarket spun-alum YSR wheels and an alum. fuel tank that my mini racer could be considered light.
That's about it, but there might be more later.
When I quit racing, I gave the NS to a racing buddy who had a place near Tombstone Az. We've been out of touch for years, but now that I am retired, I'm moving back to Az. next month. I'm going to try and track old #55 down. I wouldn't be suprised if it isn't sitting in a barn somewhere in Cochise Co.
motomech
Post by motomech »
z50r-ghost wrote::?: -can anyone spot the very special part I added to my NS's engine that is a big "power adder?"- :?:
:mrgreen:
I don't know, maybe the reed block spacer?
or pehaps that little veolicity stack
Ghost, could you slide the fork legs further up in the clamps?
I can't remember if the top crown allows that.
Thank you ghost for the good shots.
Can't find the mystery-mod.... :confused:
Those directional spokes are spectacular in white... :love:
Only 54 days until this project culminates in Georgia, and I hope to be there and give good chase.... :urban:
GKinTN
Post by GKinTN »
Totally awesome! The white wheels look great, and it's very cool that you now have front and rear discs. I also like the fact that you went with the stock colors. GK
paulpauly7
Post by paulpauly7 »
whats the special mod ?
z50r-ghost
Thanks for all your compliments, guys; they mean a lot!
-motomech, thanks for your time in writing up all your trials with the NS50F; I can't wait to hear more dude! You have done some massive work with the NS... Very, very impressive.
The fork tubes on the NS cannot be moved, because the handle bars bolt to the triples, which is a "stop" for the fork tube caps. I am working on a setup for preload caps right now.
Motormike; definitely looking forward to "True Grits" this year... I just set the countdown on my phone. Haha!
As for the "power adder" I mentioned, good guess on the reed spacer and V stack.
The part I was referring to is the cylinder head. Externally it looks different from the NS head because of the water outlet location. This model head is for the NS-1.
This is a new factory Honda part that Autoboyss Japan completely re worked that matches my 63cc Daytona bore setup. The squish is amazing! I will take some pics comparing this head to a stock Honda HRC head, then the factory NS50F head. :shock:
Here is a tip alot of Japanese guys do with their NS50 / NSR50 engines:
To add a larger carb, (such as the popular Keihin PE24):
The Honda CR80 carburetor intake manifold has the same bolt pattern as the NS intake mani.
(If you buy the CR80 intake manifold, you will also need the special oem O-Ring seal)
Part #'s
INSULATOR, CARB. 16220-GC4-600 $23.77
O-RING, SPECIAL. 91305-GC4-601. $5.02
Further, "Moose Racing" makes a reed "torque spacer" for the CR80.
By using the oem CR80 intake manifold and Moose Racing CR80 Reed spacer,
along with adding a larger carb, an oem Honda CR80 reed block and reeds can be used.
The reeds have a much larger surface area, and in addition to flowing better, throttle response will be more "crispy."
Part #:
VALVE ASSY., REED 14100-GS2-003 $47.69
Anyways, Hope this helps NS50F doods.
I really appreciate all of your positive comments and support...
Later, 8) jon
...my life story
1990HONDANS50F
That is one worthwhile project, Ghost! Keep the drool-worthy pics coming.
bradthreee
Post by bradthreee »
:worship: we're not worthy! :smile:
