Soooo... just when ya thought the saga of the dyno testing was over... IT'S NOT !!!
After having it out from the shop and doing some heat cycles and an early morning ride to Casey's for some donuts then an after noon ride to my mom's to show her the bike. I discovered the clutch is slipping !!
Looking back at the data. The dyno shows this too. Also explains the crappy take offs on the dyno even though the revving was up there.
Run 16 was done just after the Spree was started up and was still cold. In run 17 (the one in the video), we see a loss of power and a drop in torque. Compare to the video where the Spree hit 40, and horsepower was over 3...Typical glazing symptoms. I suppose I could just tear it open, try the sandpaper trick, but why bother? I'm just gonna take it out and have it re-lined.
Figures the only thing I never replaced would end up being a problem.. Ah well, that's the way it goes. Might as well put new springs in it too.
I should have been thinking to check that. When I had it running with the old piston, I had suspected it at the time as well, but wrote it off as just a wimpy motor. After driving around on my other Spree, which does have a good clutch, I can see the difference. I suppose I could just swap out clutches from the other Spree, but I'll probably end up having to replace that one as well anyway.
Won't be letting my son drive it any more until then. Don't wanna be revving that engine any higher then need be till the issue is resolved.
After that... YET ANOTHER reading on the dyno!!
Next run will only be taken up to maybe 7500-8000 RPM. Taking G9's advice about not stressing it past it's power band. Make's me wonder if his 4.5-5.5 range guess of HP is gonna be right on the money. Plus, It's had 5 heat cycles and about 10 miles of riding on it, so the engine is in a little better shape then it would be fresh off a new piston.
