Pretty sure with my old setup I ran a 42/122 combo.Wheelman-111 wrote: using 52/125 jets in the OKO 24.
51mm RUIMA
CT + 24OKO + KOSO pod
PG Long
9.1 gears
what position do you have the needle clip?Wheelman-111 wrote:Greetings:
More errands tonight, another half-hour of run time. Approaching 3 hours. RPM seldom exceeded 7400, and speeds up to 45 using 52/125 jets in the OKO 24. Still won't take full throttle, just loses power and slows a bit. Sure burbles a lot in the midrange, but can "adjust" with throttle hand. Ordered up a 50 - 48 - 45 Pilots. My temp gauge did creep above 300 or so briefly once or twice, during application of 3/4 or more throttle. That's why I don't want to drop the Main too much more.
I decided the variator was too heavily loaded even for the low-end Hot Surfaces exhaust. Dropped down to 30 grams (Stock Kymco spring) to see if I could touch 8K RPM for the next half-hour of run time.
Came within a whisker of scooter-slaying a suicidal squirrel. Reminded me of the time I ran over an adult raccoon with my XS-750 Triple, but now I'm dating myself.*
Wheelz
*The sex is good, but conversation is trite.
