So bit of an update on this and to clarrify what I am currently running.
I now have a 17mm Polini instead of the 21mm Polini. For the curious as to what the jet difference is.
The 21mm Polini comes stock with a #100 main, and a #40 pilot. The 17mm Polini comes stock with a #80 main, and a #38 pilot.
I am running the 17mm Polini with a #34 pilot (same as a stock Spree carb), with the #100 main from the old carb. Only prob I had was the boot between the intake and carb accidentally popped off a couple times, which I think I have corrected by simply using a Stage 6 CNC riser, moving that shock up about an inch or so out of the way so it isn't banging into the carb. That kind of noise can scare the LIVING HEII out of you at 45mph. First thing I thought was.. OH NO, BLEW THE ENGINE, look down, and the dang boot had come off. Gonna see if I can find time to shoot a video of it doing some road time. But anyways, if using an SB50 intake/reeds on a Spree BBK, I recommend staying with the #80 jet on the 17mm Polini/stock carb, I wouldn't up that jet much unless the Intake/reeds get ported out, or you swap out the stock intake/reed system for a suitable adapter.
Also, from what I can see, Taz is once again, offering his kits up for sale.
http://www.ebay.com/itm/222536208587
