01 Elite SR "GOOCH"
FunkeyMonkey
Re: 01 Elite SR "GOOCH"
Post by FunkeyMonkey »
Did you replace your shock or haven't tried a new one since then?
2001 Honda Elite 50
72cc malossi cylinder
24mm polini carb
Naraku intake
Rip_City_Spree
Post by Rip_City_Spree »
Yes I finally replaced the stock with the malossi offset shock and love it so far.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
Naraku sport variator
Currently 5g rollers
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
Rip_City_Spree
Slow and steady just need the cable which I know some guys have local just need to get it.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
Rip_City_Spree
Now to tune the clutch.
After
After
Before
Before
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
benji
Post by benji »
Nice stretch ! Not too long, looks just about right.
Rip_City_Spree
Thanks made it easy and had it made the same length as G9s stretch that way I could just pick up a cable and shock extension local. All I wanna do is ride but have family in town so I'm a bit grounded.
I did ride it home and feels great. Crazy my highest temp I hit was 322, I have dropped the MJ to a 102 and it's getting much better full throttle. The carb is close and now that the bike is back together I will start working on the trans. Got 7g rollers in with a yellow contra and it just isn't getting to high gear. Pulls great to 40-45 then just won't go. I am gonna put in a blue Contra and see what happens.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
You can Sharpie-mark your pulleys to see how far up toward the rim the belt goes. Think "Mercedes-Benz" logo. Also, watch the tach as you crack the throttle. Does it jump up and then down? If so the load may be too light for the spring. I find it easier to settle on a spring and then juggle the rollers, going up or down by no more than 3 grams per change. Splitting the clutch is more work.
Rip_City_Spree
Thanks Wheel. I have sharpies the pulley and will check it when I change out the contra. Pretty sure it's just not going into high gear. If I'm going down hill boom jumps to 55 ish fast. Now that the stretch business is done I'll deal with the clutch next week.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
Rip_City_Spree
Just because
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
Rip_City_Spree
Put in a blue contra this morning and gonna see how that helps. took it for a quick spin and still feels like it doesnt want to go past 40mph. any thoughts or suggestions would be appreciated.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
Peteyparado
Post by Peteyparado »
How heavy rollers u running ?
Polini 30mm carb
Naraku mani
Scorpion stroker pipe
Stage6 CDI
5gram rollers
Keli high speed Variator
6.1 gears
94mph
Rip_City_Spree
currently 7g rollers all around. might try 6.5 and 7s to see what happens. 7gs are the heaviest I have right now.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
Rip_City_Spree
Was thinking the same G. Going to lighten up tomorrow and will be going into town so I'll be able to see what's up. Started there as this was basically the setup I had with the contessa and figured that would get me close. It's crazy if there is any down hill slope it hauls(as much as this setup can.) I gpsd it on the way home and it hit 52 with a slight downhill run.ill change em tomorrow and diagnose and tweak Wednesday and when I come out you can take it for spin and help me fine tune it.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
Peteyparado
Yeah thinking the same mayb even 5s an 6s
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
Rip_City_Spree
Well the wife and kids are in Cali for a week and so I get to play. Dropped in 6g rollers all around took off. This route is pretty standard for me so I have lots of past runs to go off of. With the lighter weights it definitely ran better but it's still off. Put 30 miles on and temps got up to 355 degrees tops. Not sure how hot this kit can take. That said I think I'll put in a 100mj tomorrow and keep going lower with the weights.
It still ran ok and if the Rpms stayed up it does pretty well. Loses a bit going up hills. And hoping the lower weights help.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
