PLEASE HELP! Resurrecting 1987 SE50P Elite and derestriction
Re: PLEASE HELP!!!!
my 1 amp charger takes about an hour to charge. if i put it on 2 amp it takes a half hour ish. but that isnt completely dead, that is when i try and start my aero in the cold and the starter runs out of juice to turn the starter.
- martynkim
Re: PLEASE HELP!!!!
just took it off after 1/2 hr not enough juice
Re: PLEASE HELP!!!!
if it hasnt been ran in a while you might have trouble getting it electric started. unfortunately thats the beauty of kickstart, you only run out of juice when your too frustrated to kick it over again.
- martynkim
Re: PLEASE HELP!!!!
Kick start is a grinder it won't really work but at least it does not bind.
- martynkim
Re: PLEASE HELP!!!!
ok starter is humming along won't fire up. batt dead again. may need to prime the carb with some quick start? not sure.
- martynkim
Re: PLEASE HELP!!!!
crap better gap the plug! I was at a buddy's house when we put it in and didn't have the setting u know what it is???
Re: PLEASE HELP!!!!
seems like that new cover would fix your issue if i understand what the issue is. when its all set up kickstart is extremely reliable, i hate that about my 85 aero 50. (the only year they didnt have kickstart) when i leave home and go somewhere far, when i come back to my scoot i always pray that something didnt drain my battery down.
dont use starter fluid, i read somewhere on here that that can be bad. i have to crank my scoot for about a minute to get gas up to itwhen the lines are dry. plug the holes at the airbox if you can, that will help choke it.
plug gap, if you bought an ngk that was ment for the scoot, you shouldnt really have to worry about it. (correct me if im wrong) but it might help, especially if it is on the edge of firing up.
Re: PLEASE HELP!!!!
do you know if it has ran recently? i just read your first post and realized you havent ran it before. is the carb clean?
- martynkim
Re: PLEASE HELP!!!!
uhhhh Went to schucks and got an autolite that's what was in it! I'll hook it up with something better later as I will probably foul this one out just getting it running.
- martynkim
Re: PLEASE HELP!!!!
I'd say at least a year since it ran. guess I should remove the carb open er up and blow it out.
Re: PLEASE HELP!!!!
i would. if you are just trying to see if it runs you could just leave it like it is, at least check to make sure fuel is getting to the float bowl and into the manifold
- martynkim
Re: PLEASE HELP!!!!
yeah i think im gonna rip the carb off and let er sit in carb cleaner all night give it a good blow with the compressor in the morning and see what happens
Re: PLEASE HELP!!!!
leave the plastic fload and the needle with the rubbery black tip out of the carb clean. sounds good though, its good to have it all ready so when you get it to fire, you can throw your helmet on and let her rip.
- martynkim
Re: PLEASE HELP!!!!
yeah most honda carbs this old need to be cleaned my 77 nc50 would'nt go for nothin without a good soak in the cleaner. I sprayed that thing out 2-3 times and it just kept choking out now shes about 80% restored and hummin along love that bike just hate the prehistoric start. Although my 86 spree came as a runner never an issue just needed a battery and a license. (my wifes bike) I'm hoping to get this elite going so we can ride together. not as much fun by yourself.
Re: PLEASE HELP!!!!
i hear ya. the aero was my first scooter, then i bought my elite and now im teaching my fiance' to ride safely.
