Give Your Spree More HP
1984 85 are faster
hello guys my name is martin i live in puertorico i hade about 30 sprees and i now all their little secrets 84 85 models are completely diferent smoler rod closer spark to piston gap and do run 38 to 41 in stock mode...for now i will tell you yust one trick...put a 84 or 85 cilinder head on a 86 or 87 model and you will get and xtra 4 to 7 mph.. i garanteed it ps some may get hot so use the gasket....
try the head swap you wont be desapointed
to free more power also ive done this home made header manny times....listen cearfoly first take a grinder and cut open the stock mufler by the middle take out all the chambers and fiber glass noise supresor youst leaving a big tube that it has inside at the end of the pipe and aiso leave 2 eanches of the small tube at the end of the pipe.. then wheld it ..you will have exactly the sound of a 2 cicle four track ..you might loase a bit low end torque but you will gain top end...ps it will be mutch noisier......the faster spree i saw back in the 80s with its stock motor and this and a few other tricks ran 47 mph.....and is no yoke....
Blow up? What does that mean, literally blow up, if its to high compression or not enough clearance? I would image if the compression is to high, just to increase the octance level, perhaps 93 octane, now if its a clearance issue I would say to bad wont work, However I will try it to see what happens. If anyone here has tried it with bad results please let me know before I destroy my engine.
Dont know about the head gasket, I peeled my old one off and it came off cleanly, the only reason I would say no is because it is compressed. Anyhow sometime next week i will have my spree running, hopefully I can get it to keep up with my modified Honda metropolitan, so far it out accerlates it but is limited to 34mph, compared to my metro's 40+mph.
