Hotwire
Re: Hotwire
Bear45-80 wrote:Since I don't have an ignition switch with a key to it out to check, but the last letter and 2 numbers looks like a key number to me. I've got keys that start with an "A", "B", "C" and a "D" with two digits after the letter. Can anybody confirm or deny this?
Yes - my key matches what you say, and the ignition switch has the same 3 trailing digits...
jlopez8 wrote:is it easy to see or do i have to unplug all the wires and disconnect it just to see the key numbers
We all have been putting more time into this than it would take you to check numbers or to remove the 2 screws Put some work into your 'scoot - It's part of the fun :lol:
fightingplankton
Re: Hotwire
Post by fightingplankton »
step by step if its what it takes to end this thread.
1. remove horn cover
2. remove leg shield plastic(1 bolt half way up, 2 more under the floor board)
3. detach ignition switch from wiring harness(there is a plastic coupler)
4. remove the 2 10mm bolts attaching the mounting bracket to the frame
5. remove the 2 philips head screws that attach the bracket to the ignition switch
6. read numbers
7. email/pm chopchop123(on ebay) or Tazland001(hondaspree.net) with your key code
8. send paypal to taz(i believe he charges $15 for a set...i could be wrong)
9. re-attach mounting bracket to ignition, bracket to frame, plastic,and horn cover
10. sit back and let taz do his thing.
11. open package key arrives in
12. remove key from package
13. put key into previously re-installed ignition switch
14. turn key 1/4 turn clockwise
15. hold down left brake handle
16. press start button
17. assuming your battery is charge, and your starter motor is working properly...you should now be...
18. riding
Last edited by fightingplankton on Wed Aug 18, 2010 2:28 am, edited 1 time in total.
'86 spree
'86 aero50
'83 aero80
fightingplankton
Re: Hotwire
in the meantime, if you want to get it to run...
remember where you disconnected the ignition from the wiring harness?
you can use that to hotwire it.
there are 4 wires that run into that plastic coupler.
one is black, one is red, one is green, and the last is black w/ white stripe.
if you use a wire(not small gauge) to jump between the red and black wires by jamming it into that coupler, you can still get your bike to start.
by the way...this should be done on the harness side of the coupler...not the ignition side(i know it seems obvious, but i thought i'd clarify).
now, this is temporary of course since that wire is bound to fall out since you didnt actually attach it to anything.
the other way to do it is to de-solder the wires from the ignition and use a twist cap on the end.
since you dont have a kick start, you need a momentary push button jumped between the red wire and the red/yellow wire that connect to your starter relay(located just under the seat on the right-hand side(i think, i dont have a spree in front of me atm).)
i think the key cut way is a safer bet for someone who is inexperienced in electronics...so...maybe i shouldnt even be confusing you with all this info...just trying to help.
'86 spree
'86 aero50
'83 aero80
Re: Hotwire
Why don't you go back and look at the nice pictures and read what was told to you. If you really are this dumb, you had better sell the scooter now, because you will die on it in less than a week from doing something incredibly stupid. Image
86spreezy
Re: Hotwire
Post by 86spreezy »
I think the OP needs to go back to school
Re: Hotwire
86spreezy wrote:I think the OP needs to go back to school
I don't think more schooling will help. I don't think you can fix stupid that is this bad. :jack:
zuphilius
Re: Hotwire
Post by zuphilius »
This guy kind of reminds me of someone playing WOW or surfing *, and every so often between turns or strokes pops back in here and nonchalantly types in another question to your answer, then goes back to the two choices above, only to repeat the process over and over.
I'm done with this thread.
toboggan
Re: Hotwire
Post by toboggan »
hahahahahahahahaha, oh lordy, this is assinine. so let's face it, what i said was true, he's an IDIOT.
let's all just stop posting on this thread. haha let him read, and re-read however many times it takes him for it to sink into his thick skull
Re: Hotwire
That's the biggest problem with him, he either doesn't read the answers or can't comprehend what he reads and just post another stupid question. Maybe we need a common sense test before they are allowed to post.
I don't mind someone not knowing, but after they have been told several time, there just isn't any excuse anymore.
