Page 4 of 5
Re: this is what happened
Posted: Sat Oct 30, 2010 1:29 pm
nitroelite419 wrote:im going to install the other fuel filter and see what happens, I hope thats the problem, I took the bowl off, its clean. The float wasnt sticking, so i dont know. Ill just have to try the filter..
If you are having fuel run out the overflow then the needle and seat can NOT be good, because that is the only way fuel can get into the carb. If it is working properly you can not have fuel out the overflow vent.
Oh and the bigger the number on the jet, the bigger the hole in the jet, hence the richer mixture.
Posted: Sat Oct 30, 2010 2:03 pm
by nitroelite419
so then should i raise or lower the needle, or are you talking about the little needle connected to the float
Posted: Sat Oct 30, 2010 2:15 pm
nitroelite419 wrote:so then should i raise or lower the needle, or are you talking about the little needle connected to the float
Needle and seat always refers to the float bowl system that controls fuel level in the float bowl. The needle does nothing until at least 1/4 throttle.
Posted: Sat Oct 30, 2010 5:55 pm
by nitroelite419
ok got the fuel issue undercontrol, But im still having smoke and bogging issues. d*** all i want to do is ride and go fast. i can rev up to like 1/4 throttle then it dies.
Posted: Sat Oct 30, 2010 7:43 pm
by veedubh20
it is not like gas and go. :lol:
motor need to be tunes.
is the block port, before 50mm bore kit install?
it very common on rear piston/cylinder jug , lack off cooling a piston, a/f is blocking through.
Posted: Sat Oct 30, 2010 8:10 pm
by nitroelite419
i guess im having a little trouble understanding the question.
Posted: Sat Oct 30, 2010 10:48 pm
by odinxxix
he is asking if the block was ported before the bbk was put on.
Posted: Sun Oct 31, 2010 8:24 am
by nitroelite419
no the block was or isnt ported, should it be,
Posted: Sun Oct 31, 2010 12:17 pm
by Trafficjamz
nitroelite419 wrote:no the block was or isnt ported, should it be,
Yes it should be, for optimum performance and cooling. I don't think that it not being ported is the reason your scooter running poorly.
Posted: Sun Oct 31, 2010 12:38 pm
by nitroelite419
what or how should the block be ported, sorry for all the dumb ?'s
Posted: Sun Oct 31, 2010 12:42 pm
by Trafficjamz
nitroelite419 wrote:ok got my jet kits installed a 140 main and a 50 pilot, my idels good, but now its dripping oil out of the exhaust and theres a lot of gas comin out the carb???????
140 on the main is probably a little rich (too big of a number)
What air filter are you using? I have never had good luck with the k&n style filters that come with many of the carb kits.
Take off your air filter and see if it runs better.
If it does......I would suggest a UNI filter, and a smaller main jet.
Once you get it to run well enough to do a plug chop, I would like to see what your plug looks like.
Posted: Sun Oct 31, 2010 12:51 pm
by Trafficjamz
nitroelite419 wrote:what or how should the block be ported, sorry for all the dumb ?'s
The entire engine must be torn down,and case halves separated, to port the block.
Un-ported
Ported
Posted: Sun Oct 31, 2010 1:53 pm
by nitroelite419
im running the filter that came with the carb just looks like every other filter you can buy, whats the diff with the uni filter. When porting the block about how much is taken off. So if 140 is to big of a main you think what size should i try.
Posted: Sun Oct 31, 2010 3:55 pm
by Trafficjamz
try 135 if taking the air filter off helps at all.
Posted: Sun Oct 31, 2010 4:47 pm
by nitroelite419
well took of the filter and i really couldnt tell a diff. UUHH i dont know!!!!!!!! i just tried 50:1 and it is still smokey as * and boggy.
