1985 aero 50 mods
- fastplastic
Re: 1985 aero 50 mods
is that a stock ruckus or after-market var.?
its from a stock one, unsure of mileage but, says the rollers are still useable
1985 aero 50
ported
custom exhaust
ruckus vario
1K polini clutch springs
hopefully nh80 powered soon!
ported
custom exhaust
ruckus vario
yay i got the vario today now i have a question about the roller wieghts and the ramp plate this variator had no grease in it but the aero's is packed full, so does the ruckus variator need grease? and if i were to polish and smooth out the rough spots on the ramp plate along with putting in some grease would that make my rollers last longer?
1985 aero 50
ported
custom exhaust
ruckus vario
ported
custom exhaust
ruckus vario
The Aero and early Elites used grease, but Honda-san himself deemed the messy stuff unnecessary in later models. The thing that can save rollers is to round off the sharp (Knife-edge, actually) edge on the rim of the ramp plate with a stone or a file.
Using grease without a grease cover and o-ring will make a mess of your belt. It's just not necessary.
cool i put it all together and she runs a whole lot faster now i can finally speed! rounded off that edge and then went ahead and put just a dab of grease on each roller to prevent them from getting stuck, they had some flat spots but i went ahead and reused them anyway, i looked at the aero's rollers and they were fine but when i weighed them the ruckus' were 8g and the aero's were 10g so i wasn't sure if that would mess with performance
1985 aero 50
ported
custom exhaust
ruckus vario
ported
custom exhaust
ruckus vario
- ScooterTweaks
- BMX
I have taken my variators on all of my scooters with the AF05E and cleaned all the grease out and removed the o ring and rear grease cover with no problems. It seems faster on the top end on some scooters. Besides, once I find the weight I need I will put in some sliders and not worry about the flat spots. Anyone used the doctor pulley sliders? I have used them on my Kymco 250cc, Derbi scooters, and an Aprilia SR50 with success. I plan on using sliders in my Honda scoots when done.
Anyone found other issues when removing the rear plate???
Cool thread we have here.
ScooterSteve
ScooterSteve
ScooterSteve
ScooterTweaks
512-88-SCOOT
Honda (1984 Spree, 1985/1986 Aero, 1987 Elite SE50, 2008 Metropolitan)
Derbi (1999 Predator, 2002/2003/2004 GP1, 2004 GPR50
2002 Kymco B&W 250
2003 Aprilia Scarabeo 50
2004 Yamaha Majesty 400
2009 Sym Mio 50
ScooterTweaks
512-88-SCOOT
2002 Kymco B&W 250
2009 Sym Mio 50
Replacing rollers with sliders is not a gram per gram thing. The sliders have to be heavier. How much, I haven't been able to find out anywhere I've looked, so good luck.ScooterTweaks wrote:I have taken my variators on all of my scooters with the AF05E and cleaned all the grease out and removed the o ring and rear grease cover with no problems. It seems faster on the top end on some scooters. Besides, once I find the weight I need I will put in some sliders and not worry about the flat spots. Anyone used the doctor pulley sliders? I have used them on my Kymco 250cc, Derbi scooters, and an Aprilia SR50 with success. I plan on using sliders in my Honda scoots when done.
ScooterSteve
i was bored tonight so i made a new expansion pipe after reading jennings 2 stroke exhaust article and now have a working pipe after shorting down the length to 16in and sliming the max diameter down to 2.9 inches, ill post some pics tomorrow after i clean and paint it
1985 aero 50
ported
custom exhaust
ruckus vario
ported
custom exhaust
ruckus vario
hey heres my pipe finally got a pic, and sorry for the hideous paint job just put on something to keep it from getting rusted out, just wanted to show how compact it was and it actually turned out pretty quiet
- SAM_0646.jpg (64.64 KiB) Viewed 5969 times
- SAM_0647.jpg (78.92 KiB) Viewed 5969 times
- SAM_0642.jpg (85.9 KiB) Viewed 5969 times
1985 aero 50
ported
custom exhaust
ruckus vario
ported
custom exhaust
ruckus vario
Is that a spray paint can silencer? If so I like it! may have to do something similar on my cub.
'62 125cc Honda cub
'62 125cc Honda cub
lol ya its a big brake cleaner can with glass insulation heres a pic from a dirt bike exhaust i made awhile back
- SAM_0622.jpg (27.71 KiB) Viewed 5955 times
1985 aero 50
ported
custom exhaust
ruckus vario
ported
custom exhaust
ruckus vario
anyone know minimum and max watts the aero50 produces or if it matters?, there is this super tiny 80 watt inverter at harbor freight i want to wire into my glove box, i want to say there was a 50 watt one but i dont remember http://www.harborfreight.com/automotive ... 66972.html
i was also wondering how much work it would be to drop an aero/elite 80 or 125 motor in
1985 aero 50
ported
custom exhaust
ruckus vario
ported
custom exhaust
ruckus vario
Mousewheels is Electron-Expert.
Swapping in a bigger Stock 2-stroker has been done, just a question of sorting out motor mounts, shocks and wires.
However AF16 "Dio" swaps are easier, the engines more modifiable to go faster, plus they're easier both to find and to obtain replacement parts.
Swapping in a 4-Stroker would be Heresy. And slower.
96 watts at 5,000 RPM for '85 and newer and only 89 watts at 5,000 RPM for the '83 and '84, so the inverter is guaranteed to kill your battery real fast at anything other than WOT.bc117 wrote:anyone know minimum and max watts the aero50 produces or if it matters?, there is this super tiny 80 watt inverter at harbor freight i want to wire into my glove box, i want to say there was a 50 watt one but i dont remember http://www.harborfreight.com/automotive ... 66972.html
thats alot more than i thought it made is there a method to calculate the watts? like maybe 96/5 = 19.2 watts per 1000rpm so like +/-30watts at idle? 150 watts at 8000rpm?, anyone know of a smaller inverter, and while im asking stuff my fuel gauge is messed up i filled up the tank to the little bar the blocks the pump and the needle was under full then after maybe 10-15 miles i was reading less than half full, another 10-15miles i was reading empty, so i stop and look in the tank and im guessing im about 1/2 full, anyway to calibrate it i pulled the apparatus out of the tank and moved it with the key in and the guage seemed to read accurate to float position, so what bad float, bent arm, what?
1985 aero 50
ported
custom exhaust
ruckus vario
ported
custom exhaust
ruckus vario
