Superman -vs- Kryptonite 125cc stroker battle (new videos)
- SpreeMadness520
Re: Superman -vs- Kryptonite 125cc stroker battle
Were is the update? It has to be running by now
- Trafficjamz
I will fire it up tomorrow for the first time.ottoman wrote:Were is the update? It has to be running by now
I finally got all the new parts in
Whoohooo!!!
cant wait to see what it does!!
- Trafficjamz
Started it up to day and ran it til the head temp reached 350 then shut it down.
I am done with the 4th heat cycle so far.
I will go for a ride soon after the tenth heat cycle
anyone have Idea's for jetting? It is 60pilot and 160 main on a 30mm oko right now.
Seems to idle kinda high right now.
I burnt a 90cc Ruima 51 Ministroker running at or just below 60/160 in a 30mm OKO. There might have been other reasons, but to me that jet combo still sounds pretty small for a 125.
- Trafficjamz
Wheelman-111 wrote:Greetings:
Any suggestions ? I have lots of bigger jets.
I dunno, Dawg... Bigger, I guess. How much bigger? Not sure but I can send you my ex-Sportster Mains up to 205...
Seriously, consider going ludicrously big - like 175/70 and swap down until it runs. Then carefully swap down until it runs well.
ITS ALIVE!!!!!
I dunno... Im running a 145... same pipe and kit and was thinking of leaning it out some based on the plug reading.
Only way to really know is to test.
- Trafficjamz
Do you have a 30mm carb too?ottoman wrote:I dunno... Im running a 145... same pipe and kit and was thinking of leaning it out some based on the plug reading.
Same crank... same bbk... same pipe and same carb.
d*** Bens gonna kick your butt... he has a better pipe, intake and carb
- fastplastic
but we have to see if he can tune it
- Trafficjamz
we will seeottoman wrote:Same crank... same bbk... same pipe and same carb.
most 1/8th mile races are won in the first 60 ft
Very true, unless there is a massive horsepower difference.Trafficjamz wrote:we will seeottoman wrote:Same crank... same bbk... same pipe and same carb.
d*** Bens gonna kick your butt... he has a better pipe, intake and carb![]()
