44mm or 48mm BBK
Re: 44mm or 48mm BBK
spree-rider wrote:NO
:confused:
Yes porting will help any engine
Agreed
tazland001
Post by tazland001 »
Good post Hammer. Let me know what results you come up with as far as performance goes. I am always trying to improve my product to get the best results for my customers. Is there any changes I could make to the 48mm kit from the maker to help it balance a little better? Any suggestion would be appretiated.
As far as performance parts I do what I can and do my best. In my experience the 48mm kit on my spree and elite e feels like it has a lot more power to give but is restricted by the small intake of the carb.
Taz
spree-rider
Post by spree-rider »
it will help but not significantly.
86 spree
sb 50 intake and reeds
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
high compression head
chrome low windshield
mountain bar
Xtra-10
I ALWAYS KEEP ONE ROLLED
Not without an bigger intake and carb and a better exhaust.
spewya
Post by spewya »
Bear45-70 wrote:Not without an bigger intake and carb and a better exhaust.
ill have a better pipe and a ported intake .posibly ported exaust port.mabe make some carbonfiber reeds,, with all that will up jetting be nessisary
spree parts for sale
still learning alot ..thanks to all on this fourm
if you have a good spree jug ..pm me if you want to sell it
I do not believe a ported intake will make any difference or enough for you to see it without a real good GPS. Mainly because the reed cage is the restriction in the intake system. The reed cage from an SB50 has slightly bigger openings than the Spree but I know for a fact the Spree reed petals will work on the SB50 reed cage. Oh I have a couple sets of carbon fiber reeds for the Spree and I have yet to try them on either the Spree or SB50 intake systems. I've been working on my bigger cc Aeros, so maybe some time this summer I will get back to the Spree and the 1985 Aero 50.
Bear45-70 wrote: The reed cage from an SB50 has slightly bigger openings than the Spree but I know for a fact the Spree reed petals will work on the SB50 reed cage.
The SB50 reed cage is the same as a 1987 spree
Actually the '85, '86 and '87 Spree all use the same reed cage as does the 1985 Aero NB50. PN# 14100-GN2-010 Which replaced the original reed assembly in all 4 engines. PN# 14100-GN2-000
The 1988 SB50 and SB50P, 1989 and '90 SB50P all use a different reed block assembly. PN# 14100-GS6-010
Bear45-70 wrote:Actually the '85, '86 and '87 Spree all use the same reed cage as does the 1985 Aero NB50. PN# 14100-GN2-010 Which replaced the original reed assembly in all 4 engines. PN# 14100-GN2-000
I can't say for sure that they were not changed at some point.....but I have big and small reed blocks from sprees. :confused:
That info is straight from my Honda Cross Reference.
bc117
Post by bc117 »
so bear are you saying the sb50 reed block will is better than the 85 aero's
1985 aero 50
ported
custom exhaust
ruckus vario
1K polini clutch springs
hopefully nh80 powered soon!
bc117 wrote:so bear are you saying the sb50 reed block will is better than the 85 aero's
No, I am saying they are different. I have never had an SB50 reed in my hand, so I can not say.
spewya
Post by spewya »
will the sb50 reeds fit on an 86 spree with a spree stock intake ...
hey bear would you wana sell a set of those carbon fiber reeds for the spree
The 1986-87 Sprees, all the SB50s and the 1985 Aero 50 all used the same gasket so the reed block will fit. The 1984-85 Spree shows a different gasket but I know the '86-'87 gasket fits on the '84-'85 Spree, so yeah, they should all fit.
I would have to think about the reed thing.
