Page 4 of 4
Re: EPIC 1985 aero 50/80 swap
Posted: Wed May 04, 2011 7:15 pm
bc117 wrote:wow really wish i could post pics but my camera is missing its charger, i got the engine to sit perfectly for the carb to work and took it for a ride, lol wow it really hauls * its like a turbo diesel aero 50 now but really wont do much more than 39-40mph it feels like im getting the dreaded lean topend because it will bury the needle at 3/4 throttle downhill but will slow down at wot.
The Aero 80 came from the factory with a slightly too lean main jet. Change out the stock 88 main jet for a 90 and the throttle will be able to be held wide open then. You won't go any faster but you will be able to hold WOT. Oh and a 92 is too much.
PN# 99102-GHB-0900 from Honda.
Posted: Wed May 04, 2011 9:02 pm
by bc117
What size jet the opened up aero 50 airbox, and the eventual custom pipe I will add
Posted: Sun May 08, 2011 12:41 pm
by PolarIce
Find your camera charger already...
Posted: Tue May 17, 2011 10:08 am
by bc117
sorry about the photo situation ill try to get some soon just been doing other stuff
, any one know the dimensions of the aero 80 drive belt and would there be any benefit to going with a wider belt, mine appears to be so worn that it just slides between the variator faces, and BTW i have managed to get up to 45mph on the flat but my pipe is all topend kicking in at 20-25mph then it really takes off until it levels out at 45ish feels like it has plenty of power as it will maintain 35+ and actually accelerate up hill as long as i am in the powerband, if the new belt doesn't help my bottom end, does any one know if the sleeker 1985 exhaust will fit my 83 cylinder
Posted: Tue May 17, 2011 2:05 pm
The Aero 80 belt measures 745 mm X 15 mm X 30┬░ (or 29.33" X .59" X 30┬░ . The wear limit on the belt is 13.5 mm. Honda Part Number 23100-GC8-004 List $37.95 Cost $25.88
