Any need for larger caburetor?
Bugaboo
Re: Any need for larger caburetor?
Post by Bugaboo »
Got the 24mm oko and 4 reed manifold. Fabricated an adaptor plate out of sheet metal and mounted everything yesterday. Putting up some pics soon.
These are the jets I got
1 x MAIN JET for PWK KEIHIN OKO #118 £2.90
1 x MAIN JET for PWK KEIHIN OKO #120 £2.90
1 x MAIN JET for PWK KEIHIN OKO #122 £2.90
1 x MAIN JET for PWK KEIHIN OKO #125 £2.90
1 x SLOW / PILOT JET for PWK KEIHIN OKO #48 £3.10
1 x SLOW / PILOT JET for PWK KEIHIN OKO #45 £3.10
1 x SLOW / PILOT JET for PWK KEIHIN OKO #50 £3.10
Will start big and move down if things point that way.
Probably getting a uni filter even though I received one with my carb.
I've heard of spraying carb cleaner at any seams and listen for any changes in engine revs to check for leaks. Anyone had success with this? I'm very anxious to see if my sheet metal adaptor will pay off.
It's official! I'm addicted
I use an unlit propane torch to check for vac leaks. It does work. If you fumigate the filter, you can hear the rev change immediately. Then move to any place a leak is suspected and listen for similar change in RPM. Remember that some vac leaks are speed/vibration/bump-dependent, so it isn't foolproof.
Bugaboo
Post by Bugaboo »
Some day I may set up a pressure test system by plugging the exhaust port and manifold, but using the carb cleaner or propane torch seems so much more practical.
Just mocked up my wild lion exhaust today. Definitely not a perfect fit. Fiddled around for some time. Ended up grinding of some weld and widening the chamber mount holes. Waiting for my jets to arrive and then it's show time.
Bugaboo wrote:Some day I may set up a pressure test system by plugging the exhaust port and manifold, but using the carb cleaner or propane torch seems so much more practical.............................
Been done for vacuum and pressure testing the crankcase seals. The spraying is 20 times easier.
Bugaboo
Post by Bugaboo »
Only advantage I can see is not having the risk of starting an engine that has an air leak.
Bugaboo
Post by Bugaboo »
Here's a pic of my adaptor. Not trimmed around the contour of the manifold but I don't see the point in making those difficult cuts until I see that the thing works, so it's just a large square cut to clear the cylinder and left case. The gap between the manifold and sheet metal may look big because I used perm marker to get outlin of manifold on to the sheet metal and never cleaned it off. My jets showed up as I was typing this.
Geez, someone who takes more out of focus pictures than Wheelman or me. :bowrofl:
Bugaboo
Post by Bugaboo »
My batteries were out so I used my girlfriend camera. Just cross your eyes you'll see it just fine
Bugaboo
Post by Bugaboo »
built and did pressure test. Solved problem leaks: oil plug and my actual tester leaked. Crankcase gasket was good which was what i was worried about because it's something I was not comfortable fixing. Pressure did not hold at 6psi for 6 mins. The seam after the reed before the manifold leaks. Not at bolt holes and gasket. Any liquid gasket suggestions (rtv, anarobic gasket, etc)? Bolts tightened as much as i can.
Bugaboo
Post by Bugaboo »
Oh I will be doing vacuum test too. Renting vacuum pump soon. Once manifold leak is solved will still be doing starter fluid/carb cleaner/propane test also. Surprisingly my self-made sheet metal manifold held pressure
dun rite
Post by dun rite »
Hello. Not sure but maybe Honda bond. same stuff used to seal crankcase. Might make almost impossible to remove later though.
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
Bugaboo
Post by Bugaboo »
dun rite wrote:Hello. Not sure but maybe Honda bond. same stuff used to seal crankcase. Might make almost impossible to remove later though.
Not sure if i'm concerned about getting it off later just want good seal and no ill effects from peices falling off or chemical reaction
fastplastic
Post by fastplastic »
kingkamehameha wrote:Waste time just build a dio son
some people like wasting time and money.... been there done that! thats why i have a dio spree :geekdance:
Petrock's 1984 Spree
Post by Petrock's 1984 Spree »
A little Hondabond works great and it is easy to remove to, I've used it on my intake and on my gear cover with gaskets. To get them off you take out all the bolts and gently tap it with a rubber mallet and the two pieces come right apart.
Complete NOOB, sorry dudes
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-Polini 2 Shoe Clutch
-Koso Vented Clutch Bell
-669x18x30 Belt
Bugaboo
Post by Bugaboo »
Ok thanks
Got some honda bond yesterday. A little of that stuff goes a long way. Letting it set and will do another pressure test over the weekend
