Page 4 of 4
Re: SYM DD50 Build...
Posted: Tue Aug 09, 2011 2:29 am
by donaudi
Posted: Tue Aug 09, 2011 2:37 am
by donaudi
Posted: Tue Aug 09, 2011 11:27 pm
by Red Eft Performance
Thanks Donaudi.
Will need the deck height to figure out the timing.
Posted: Thu Aug 18, 2011 5:51 pm
by HI808SYM
i was wondering how your build was going.
thinking of running a similat setup.
did you do any block porting? i know my SYM has a mini boost port and really small intake ports.
Posted: Sat Aug 20, 2011 11:17 pm
by veedubh20
I can port sym block.
Posted: Tue Aug 23, 2011 6:20 pm
by HI808SYM
veedubh20 wrote:I can port sym block.
wish i could
Posted: Thu Apr 12, 2012 12:51 am
by dv/dt
Soooooooooo, did anything ever materialize from this collection of parts?
Posted: Mon Jul 08, 2013 4:59 pm
by deuce217
GREAT JOB! I am glad you are taking your time to share this work. Thank you.
Posted: Tue Jul 09, 2013 1:19 am
Ya its to bad Im not sure what happened to him. He hasnt been around in a couple of years.
Posted: Tue Jul 09, 2013 1:22 am
by deuce217
Hopefully that CBR did not take him out of the game. I am glad I got rid of my ZX6R, nothing but trouble waiting to happen. He had a nice bike. Hopefully he pops back in.
Posted: Wed Jul 10, 2013 3:38 pm
by kauaikai
what do you guys think is better corsa with malossi full counter or MHR aluminum with full counter?
Posted: Sun Jul 14, 2013 1:28 pm
by veedubh20
depend what pipe going to run...
Posted: Thu Jul 18, 2013 2:33 am
by kauaikai
veedubh20 wrote:depend what pipe going to run...
scorpion
Posted: Sun Oct 27, 2013 12:34 am
by ped
donaudi wrote:I dove into the contents only to be disappointed. I actually thought she had purchased the contessa kit packaged in the corsa box. Why you ask. Well, the exhaust port was rough, transfer ports on the cylinder side were not straight, piston did not look graphite coated, spark plug was cheap, etc. After some investigation into the matter, I found I had the correct kit.
So begins the process of getting the parts up to specs.
Here's the exhaust port after a lot of hours working it. Notice it's still really rough. I used a dermal with those fiber sanding discs, hand sand with 2000 grit, and finial polish with buffer bit and some fritz polish. There was also a GP stamped into the side of the exhaust port. Does anyone else have this, or can someone confirm that this is normal?
I herd the GP is the person who did the port work on the head? but im not sure if it's true.
I was also disappointed with the finish on the head by the spark plug recess. It was rough and had a sharp edge. Out came the wet/dry sand paper. I'm also going to try and smooth out the CNC ridges from the cylinder head surfaces later. I don't know if it will make a difference, but I figure it would make it harder for the carbon to stick to and lower the compression a hair.
Posted: Fri Jan 09, 2015 9:15 pm
by johnny248
I know this is old, so I don't know what kind of response I see, but regarding the Corsa and porting/polishing/cleaning up/etc, I was under the impression that this BBK already had work done by hand on it at Polini, which is what makes it different from the Contessa.
That being said, if the cylinder isn't really ported and cleaned up from Polini, is there any real reason to go with the Corsa over the Contessa? Is anything different? And when I buy this corsa am I going to have to clean up the exhaust ports etc? A little confused now.
