I dont get it
Re: I dont get it
I am not asking for a magic answer. I figure I can post questions and rammble about my progress and maybe someone may mention something I may have overlooked. I am not begging for help. I dont think you know as much as you claim to know and I really dont NEED any particular advice from you I was just being courteous to consider what you were saying. I am not trying to copy anyone else's build. I am sure if I was hanging on every thing you said you would have a different attitude
- swimmingfree
Re: I dont get it
so how the marks on the variator how close are you getting to the out side ??? a photo wood be nice ..
- kingkamehameha
Re: I dont get it
Nah im just tellin you da truth. Im not telling to run a huge 28mm. Im telling you to get a 24 and a better pipe and your set up will be alot quicker. Try the 8.44:1 gears and 8s and 9s with some polini natural springs with your 1.5k center. Its a really nice combo. What kind of oil did you put in the gear case
- kingkamehameha
Re: I dont get it
According to the gear chart you need to be revving to 8k just to go 50mph. Get a tach and see how high your revving your bore up to. A gear change to 8.44:1 will give you 5 mph more top speed at 8k
- swimmingfree
Re: I dont get it
and a stock motor ( af16 ) shod do about 8500 rpm ???
- kingkamehameha
Re: I dont get it
The rev limit on your bore is 7800. Your gearing according to the chart wont allow you to go past 50. I doubt that pipe is letting the bore rev all the way up to redline anyways. If you want to see a better top speed switch to the 8.44:1 and 24mm. Look at the gear chart if you dont believe me
- kingkamehameha
- kingkamehameha
Re: I dont get it
swimmingfree wrote:what if his timing is retard what wood happen then???
lack of hp and rpm like a retreated cdi box it wood not get the max rpm to get max speed... and it wood lose power at a lower rpm .. im gussing of cors but by the photo i stole from here hes doing about 7500 rpm thats if the variator is working right
there is two side of timing ...
By freeswimming at 2011-10-25
- kingkamehameha
Re: I dont get it
Trafficjamz wrote:fastplastic wrote:no there both 11.7........
If you believe what patrick (daywot) says.
corsa = 11.7 redline 9500rpm
contesta = 11.7 redline 7800rpm
Corsa kit offers a 9mph faster top speed than the standard Polini contesta kit. It is factory hand ported and has much higher rev potential (this accounts for the higher top speed).
- swimmingfree
Re: I dont get it
thank you king..
evilone
sold it to him and said he got 58 mph on it witch mean he was doing about 9500 rpms ???
becase he got the jug piston rings +++ he shod get close to the same speed +or - a couple is ok but 15 !!
evilone
Re: I dont get it
WHAT????? Where the * did you hear that total crock of BS?guen84 wrote:...........................................the plug br6hsa honda uses from the factory is a special designed for poor timing, so if you maybe bout a br_hs, that might affect your timing... but seems really doubt full since i havent heard of many people having timing issue.. ................................................
Re: I dont get it
Re: I dont get it
Those rpm #s that day noted is NOT the rev limit the bore will do. Its where peak hp is made at for that bore. It will rev much higher then that after it reaches its peak hp range. The corsa tops out at around 11.3k and the contessa is about 9900. But that doesn't mean it will match the rpm to speed on the speed calculator. You also neeed torque to get that speed also which a 72cc doesn't. On average is minus about 5-7mph of what the speed calculator says and that's max what you will see given that everything is matched and tuned to optimum running condition by air/fuel ratio,egt temp and cht temp. In most case for a non pro tunner like most on here,minus another 3to5mph.
- kingkamehameha
Re: I dont get it
not a new belt but it is still well within spec I measured it with calipers. Though when I get some extra cash I will get me a kevlar belt. It probably has about 500 miles on it Gates powerlink. I think a 5mph gain in a days time is pretty swell. I appreciate all the suggestions. It would be a lot easier if I had a tach and temp gauge. Also when I got home from this last run my plug cap had almost vibrated all the way out I dont even see how it was running hahhaha My goal is 50-55 cruise and 60 WOT and I rarely hold WOT for longer than a few minutes makes me nervous
