Page 4 of 16
Re: Looking for Scooter Mechanic in Michigan
Posted: Mon Mar 12, 2012 6:23 am
by kingkamehameha
Im not getting involved in your deals thats between you two. I forgot about the labor part
Posted: Mon Mar 12, 2012 8:31 am
by jcivince
So what would it cost to buy a stock crank, 8.4:1 gears and pay you to swap them out?
Or alternatively, what would it be to just buy and have you switch to a stock crank? (I know it might not be perfect set-up with the current gearing but if it doesn't really affect reliability, I'm OK with a slower start).
Posted: Mon Mar 12, 2012 9:31 am
by swimmingfree
dose it have a stroker kit???
it must be good and fast to have you think it did 64mph in 547 feet .. if you change the 7.5s to 8,44 the front end may come up ... i wood let tas play.. the way im looking at it wright now its faster then a car from 0 to 50 mph .. and with the compression test at 155psi give him some room to play ...
Trafficjamz as a drag guy im sure you have a 1/8 mile some were out there you test on are you going to run it and see what it dose ??
Posted: Mon Mar 12, 2012 11:45 am
by Trafficjamz
jcivince wrote:So what would it cost to buy a stock crank, 8.4:1 gears and pay you to swap them out?
A new stock crank from honda???? No idea
I have seen good used ones here for $50-$100
I have one that I will trade for your ministroke crank.
Gears are about $50 add a gasket to that $15 I charge $10 to press the new ones
If you are staying with the polini bore 7.5:1 are fine top speed should be around 60-65 mph 0-15 mph is like a stock scooter but after about 6k
rpms the polini power kicks in. :smile:
I would charge $100 to split the case, open up the intake and install the stock crank.
Posted: Mon Mar 12, 2012 11:53 am
by Trafficjamz
swimmingfree wrote:dose it have a stroker kit???
547 feet was the elevation no the distance.
It was fast.....not as fast as mine but it was quick.
I took the bore off and confirmed what I suspected.
Thats a ministroker alright.
I also discovered this :surprise:
Posted: Mon Mar 12, 2012 12:03 pm
by swimmingfree
i no better that to say your wrong .. i ask more for my info .. you have help me a lot just by reading your post ..
thanks
by Mystic
that sucks :P time to get the welder out
Posted: Mon Mar 12, 2012 12:23 pm
by jcivince
What kind of application would a stroker crank be good with? Just guessing based on your previous comments that it's probably best used with stock bore, correct?
I found new Honda cranks for $172.95+shipping. It might be wasting $75 but I'm tempted to buy the new crank and have you install that and leave the other stuff alone (and keep the ministroker crank for another who knows what/when project...).
And regarding the second picture (the uh-oh or oh crap pic that's going to require some fixing), how much for that?
Thanks!!!!
Posted: Mon Mar 12, 2012 12:32 pm
by Mystic
You can search around for a better deal on the stock crank than that. you can get a reinforced crank for less than 100 bucks new with seals and bearrings on ebay. If you are gonna spend money think about a malossi crank :D Everyone loves polini but you COULD consider a ministroker bore that you might be able to get for less than 150 including piston head everything you need to rebuild the top OR since you have all the other stuff you can get the 80cc bore kit from autotech with a v8 pipe for around 250 LOTS of options :P
Posted: Mon Mar 12, 2012 12:51 pm
by jcivince
Oh man, now the wheels are really turning in my head!
What search words would I use on eBay to find a reinforced crank and any recommendations?
Any details on Malossi crank - part number or recommendation on what's good?
Regarding the 80cc bore from Autotech (that would allow me to keep the ministroker), would I HAVE to use the v8 pipe? I need quiet in my neighborhood (and also for my wife to allow it).
At the same time, although I LOVE aftermarket parts and all that, ultimately I'd really like the following:
1. Reasonably fast (50 to 55 mph)
2. Good on gas (makes me think to stick with current gearing although I'd be sacrificing some off the line speed)
3. Not make much more noise than a stock scooter
4. Super reliable for long term use
What would be the list for achieving this combination of requirements? Please give details and $$'s if you know for sure.
Thanks!
Posted: Mon Mar 12, 2012 12:53 pm
by Trafficjamz
The ministroker works good with a 50mm bore.
Not so great with a stock bore.
The flange on the polini bore still holds the exhaust stud. So its not really a big problem,unless it breaks more
Posted: Mon Mar 12, 2012 12:55 pm
by Mystic
search honda dio on ebay and look through that stuff :D
Posted: Mon Mar 12, 2012 1:17 pm
by Trafficjamz
The 50mm bore(82cc) does not need the v8 pipe...but the stock pipe would really not be ideal. IMO
Using the stock exhaust does not mean a quiet scooter
As long as you use an aftermarket carb , the intake noise can equal the exhaust noise.
Posted: Mon Mar 12, 2012 1:21 pm
by swimmingfree
if this was your Trafficjamz what wood you do....
Posted: Mon Mar 12, 2012 1:24 pm
by eliteguy50
If you want to keep the mini stroker, I would just buy a used bottom end with stock crank. Think about the math, 175 for new crank plus 40 for bearings and seals if they can't be reused. Plus 100 for labor. That is $300. When/if you decide to do a ministroker later, that is another $100 for labor. So if you took that 400, you could buy a stock engine for the polini bore and a ministroke bore for your current bottom end.
