50mm taiwan bore info
evilone
Re: 50mm taiwan bore info
Post by evilone »
Red Eft Performance wrote:First off Evilone how are you getting your measurement? Are you measuring the same way madman is in the pic above?
Yes. So would a set of calipers be better than feeler gauges?
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
evilone
Post by evilone »
bakaracer wrote:you want more like .20mm or.23mm range.
bakaracer, what clearance do i want at the piston skirt then? Just go half the .20mm to .23mm range (that would make it close to the .004" ?
Just want to get it correct instead of killing the bore.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
bakaracer
Post by bakaracer »
the .20mm is for the top clearance. the skirt you want .05-.06mm. if you use the .04, is yours really tight or can the piston slide still?
Madman
Post by Madman »
Evilone, what do the port timings look like on your 50 mm bore? Cause it seems they are a little low on mine!
SYM dd
50mm 82cc KABOOOOOMMM
Strengthend crank
V8 typhoon
Malossi clutch springs yellow
Datona +20% center spring
kitako type x variator
Oko28mm
CT intake
evilone
Post by evilone »
bakaracer wrote:the .20mm is for the top clearance. the skirt you want .05-.06mm. if you use the .04, is yours really tight or can the piston slide still?
.002" / .051mm = piston slides on its own
.0025" / .063mm = piston very easy to slide but does not slide on its own
.003" / .076mm = snug (feels the best to me)
.004" / .102mm = piston snug (more than i like) and takes force to move it. Feeler gauge pulls out with a little force
.005" / .127mm =very snug
.006" / .152mm = almost impossible to insert gauge
.007" / .176mm = i'm gonna start damaging things if i keep tryin!
Need some more honing for sure!
Thanks bakaracer.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
evilone
Post by evilone »
Madman wrote:Evilone, what do the port timings look like on your 50 mm bore? Cause it seems they are a little low on mine!
Not ignoring you...i'll have to check later.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Madman
Post by Madman »
Did you get a chance to check it out?
Have a new 50mm kit arriving tommorow so will have more information on another brand kit form Taida Taiwan, I'm getting ready for round 2 ding ding!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Red Eft Performance
Post by Red Eft Performance »
Best would be a micrometer and a bore gauge.
Red Eft Performance
View products click => Here
atomicareprise
Post by atomicareprise »
all my stroker blocks are from taiwan..
i use sheng e and sgc..fortunately the rebore work was done correctly...
seizure can be the side effect of a bad rebore works...
PINOY SCOOTERISTA!!!
evilone
Post by evilone »
Sorry, way too busy working on a boat. Do you want a port map or just some pics? I should be able to get to it tomorrow...i had to order parts for the boat.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Red Eft Performance
Really need deck height as well to go with these maps to figure out timing.
Red Eft Performance
Madman
Post by Madman »
Ok I got my new 50mm kit and had a look on the block, it appears that on the downward stroke it does not fully clear the ports by about 2mm. Is this as Baka said before that these kits Are meant for mini stroke kits which have a longer stroke downwards? What would be the effect of running like this with the ports not fully cleared?
Thanks.
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
LMH
Post by LMH »
You need to make a spacer plate or use multiple base gaskets. Check compression after of course as it may be low and may need to mill the head or bore.
bakaracer
Post by bakaracer »
Madman wrote:Ok I got my new 50mm kit and had a look on the block, it appears that on the downward stroke it does not fully clear the ports by about 2mm. Is this as Baka said before that these kits Are meant for mini stroke kits which have a longer stroke downwards? What would be the effect of running like this with the ports not fully cleared?
Thanks.
how much does the piston sit below the deck at tdc?
Madman
Post by Madman »
Thanks.
It's about .5mm I guess!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
