yup. first pressure test were all dont with the motor off the bike. after i tried it and it ran hot i tried a pressure test on the bike with the spark plug and CHT sensor attached and have slow drop but only small leak i can find is on the gauge itself. pumped to 8psi and soaked everything with soapy water (case halfs, all gaskets, all over manifold and cylinder. only bubbles i could find is by the gauge).kingkamehameha wrote:Did you pressure test with the temp gauge on the head to make sure thats not leaking? When you did the pressure test how long did you leave it for
tried all different jetting today with the 28oko. one thing i notice is there is always a little puddle of fluid inside where the carb seats on the manifold no matter how small i run the pilot (lowest i went was 45 pilot bike still ran good with 45). also on the exhaust port of the cylinder there is a lot of unburnt fuel/oil.
got the 28oko off and put on the 24oko tonight.
will test tomorrow with 24oko. starting jets 45 pilot 132 main.
also started another motor build with spare arnada block i had. gonna see if i can get different results on that 1.
