Spree Engine Swap: Honda Elite CH80 onto Spree
Tyler VR
Re: Spree Engine Swap: Honda Elite CH80 onto Spree
Post by Tyler VR »
Done, just need to install the forks.
Tyler VR
Post by Tyler VR »
Installing...
Tyler VR
Post by Tyler VR »
patthesoundguy
Post by patthesoundguy »
Wow that is really coming together :-) I love this thread, its not the same old swap :-D
Tyler VR
Post by Tyler VR »
patthesoundguy wrote:Wow that is really coming together :-) I love this thread, its not the same old swap :-D
Yeah, this build is different for sure. :geekdance:
Tyler VR
Post by Tyler VR »
Tyler VR
Post by Tyler VR »
I decided to add this adjustable support bar like I did on my nh125 spree.
patthesoundguy
Tyler VR wrote:I decided to add this adjustable support bar like I did on my nh125 spree.
That bar is a very very good idea sprees flex with a stock motor, so I can imagine what it would be like with the big power plant stuffed in it ;-)
Tyler VR
Post by Tyler VR »
patthesoundguy wrote: That bar is a very very good idea sprees flex with a stock motor, so I can imagine what it would be like with the big power plant stuffed in it ;-)
Yup, I can really feel the difference how much the frame stiffens up.
Tyler VR
Post by Tyler VR »
Also got the oil breather mounted, more pics...
how did you get the ch80 forks to fit the narrow spree down tube?
Tyler VR
Post by Tyler VR »
Trafficjamz wrote:how did you get the ch80 forks to fit the narrow spree down tube?
The elite forks fit through the spree frame neck without issue, but the lower spree collar bearing was too narrow. I removed the collar from the frame and used my rotary dremel tool to shave some metal from the inner diameter. It was pretty easy, only took a couple mins to do.
Tyler VR
Post by Tyler VR »
Hit the bare metal with a little primer for now. I'm starting the wiring soon...
Tyler VR
Post by Tyler VR »
Got enough wiring done to run it up and down the neighborhood once in the rain, feeling some nice 4-stroke torque. 8)
I still need to hook up the lights and wire the cluster, the rear brake cable is seized even after soaking in oil the passed few days.
patthesoundguy
Dude that thing is so rad :-) I bet it wants to wheelie
