My Spree engine runs.....BACKWARDS????
Farfignugin
Post by Farfignugin »
Just to verify, the CDI unit controlls the timing, and noiseguy is right, it's not adjustable.
Spirit of 95
Post by Spirit of 95 »
It just acts like the timing is not correct. I am aware you can't adjust it but are there any other parts that would have an effect on it. I did try a different CDI unit without much luck. There is a solution to this and its probably an easy one. 2-cycle engines are not rocket science yet this one will not run correctly.
Any chance the woodruff key is missing on the engine? That would screw up the timing.
Spirit of 95
nope...woodruff key is there. I tried clearing some of the rust off the tab on the flywheel hoping it would make a difference........nope.
Spirit of 95
Now that I know to hold the rear brake to start the Spree...@*&^%...It runs until I let go of the rear brake.........Could anyone help with what I hope is the final problem I need to deal with.
MySpree
Post by MySpree »
short?
vonchuk
Post by vonchuk »
Okay; I looked at my engine. The electronic pickup can be move a little left or right when the bolts are loosened. A little filing with a small rat tail file in the mounting tab holes to eggshape the holes would allow more movement. You may have to file the tab down with a flat file to clear the engine case. This would allow for several degrees of timing. Move toward rotation to advance. Away from rotation to retard. Chuck
sprees, ciao, gilera 124, 62 vespa, yamaha 650xs
