Corsa line
Re: Corsa line
I fixed it I'm running the s*** out of it until it looses power or * up somhow I haven't got temp past 304 and it took forever to get there so I gess I'm gona try 125 main
- swimmingfree
Re: Corsa line
what jet are you running now??12gauge wrote:I haven't got temp past 304 and it took forever to get there so I gess I'm gona try 125 main
Re: Corsa line
135
Re: Corsa line
I made a gasket out of card bots and gasket seal and what about not reading anymore posts
Re: Corsa line
I changed jet to from 130 to 125 it was running a little hitter but only 260-280 still then I put my 9/1 gears in and variator and it heated up to 390 in like 8 minuts so I get I'll up jet again gears realy change temp alot
Re: Corsa line
Yeah works great Icut it out perfect to muffler , pressed it real flat and coated the * out of it in 950 f. Gasket seal
- paulpauly7
Re: Corsa line
maybe he thinks his packing cardboard is better than the copper ring that polini supplied with there kit
Re: Corsa line
I checked for leaks it was the exaughst and oil plug I made a good oil plug and I am useing the copper ring but out side of it I have the shape of mount cut out of card board converd in gasket seal real thick so it smashes down sealed wen I tighten cause my muffler is off by the slightest bit I'm not a dumb * people I appriciate the help a lot I fixed it but I figure with the cylinder and piston like I showed in the pic it would get worse eventually
Re: Corsa line
My v8 pipe doesn't line up right the copper won't line up
