Page 4 of 5
Re: 50x50 98cc stroker build
Posted: Fri Jun 12, 2015 3:30 am
by ped
hi forum.
still tuning, but took the spreedio for a 22 mile ride.
this motor is fast! plenty of power, at half throttle it just takes off.
I was riding with a friend that has a 90 cc ruckus clone. and I know it goes over 60 mph. on the open road I left him a mile behind. Lol. he was surprised, so was I.
tuning takes time which I don't have much of. But I'm very close to getting it perfectly tuned.
I may post some videos? or maybe GPS top speed. will keep you posted.
Posted: Fri Jun 12, 2015 6:17 am
by xxgamerxx
bro wat tops know! im also excited on my 98cc stroker!
Posted: Fri Jun 12, 2015 11:12 pm
by ped
xxgamerxx wrote:bro wat tops know! im also excited on my 98cc stroker!
Hi.I still have to take it easy, Plus not too many places to do a high speed test. I did get a chance to open it up on a straight Road I did not have the GPS with me if I were to guess I only went about 65 mph. still tuning to get it to 70 +.
Posted: Mon Jun 29, 2015 3:02 am
by xxgamerxx
bro any update im getting excited on ur project
Posted: Wed May 18, 2016 4:27 am
by ped
Hi forum.
I have a motor noise on 50mm.
i don't know if it's piston slap or what? noise is like a tick.
please check video noise starts at 14 sec.
https://www.youtube.com/watch?v=aRiS1CbVTmE
The compression is around 220psi. I'm also using 100 octane racing fuel. Squish it is at 1.2
I did remove the head to check the piston and the bore everything looks good. No dents or scratches. Motor has about 150 miles.
The motor runs great, and has power. 65+mph.
any advice would be greatly appreciated.
Posted: Wed May 18, 2016 4:39 pm
Yikes!! That works out to 15:1 compression ratio. This is in Diesel territory (14 to 22:1). Unlike Herr Diesel's engines however, the top-end bearing may not be up to the task of supporting that level of compression for very long. I'd suspect a little slop has developed in the little end, maybe the crank end as well. This can be checked and compared to
FSM specs.
Posted: Wed May 18, 2016 7:23 pm
by ped
Thanks Wheelman.
I did a search before posting and came up with ring wear, piston slap. all were associated with high mileage . I'm still confused because I have low miles.
I took it apart and everything looks good. Everything seems very tight.
My best guess would be Rings did not seat properly?
I'll take care of that compression right away.
When all else fails use a repair manual.
thanks Wheelman. I need to know those specs
Posted: Thu May 19, 2016 9:06 pm
by ped
Thank you Mr G. Definitely changing out the piston and rings.
I believe, I didn't do the "important" proper heat cycling and breakin.
It's not good to be in a rush. to see how fast it will go. Proper braking will save your cylinder or piston.
Posted: Thu May 19, 2016 9:20 pm
by ped
I'm going to quote someone in the Forum.
"Out with the old In with the new sister wife" LMAO.
I mean out with the old OKO in with the new polini.
from scooter Swap Shop.
After proper brakin
Posted: Sun Aug 14, 2016 2:41 pm
by ped
Hi forum.
Turned out the motor noise, was it had waaay too much compression.
motor runs really good. it does get a little hot at wot.
I'm working on the Jetting 122 m, 40p, 24oko.
Posted: Mon Aug 15, 2016 11:03 pm
by ped
hi forum. Top speed so far.
I have to change out the 24mm oko carb, and put in the 26mm polini carb from scooter swap shop.
Posted: Thu Aug 18, 2016 11:34 pm
by z50 chopper
pictures
words
very clear photos and great build by the looks of it.
Posted: Fri Aug 19, 2016 10:42 pm
by ped
graphite9 wrote:nice work ped! that thing has to be a beast to ride.
Thanks mr. G. It's actually a smooth ride, but it's also very fast.
Posted: Fri Aug 19, 2016 10:51 pm
by ped
z50 chopper wrote:
pictures
words
Thanks z50. This is my first Stroker build. it took a while to put it all together, but I'm happy with the results.
here's my top speed so far.
Posted: Sun Aug 21, 2016 3:33 am
by MrJumps
75mph, can you hokd that for a long while say 20 minute comute?
