Low dollar to high dollar budget estimates to use a 48mm BBK
eclark5483
Re: Low dollar to high dollar budget estimates to use a 48mm
Post by eclark5483 »
What mix are you running in the tank? 80:1 or 96:1?
Jonadz
Post by Jonadz »
Per the instructions Taz included im 50-1 for break in then I believe 80-1 after. My 50-1 probably isn't accurate as I was using a 1.5 oz shot glass to premix 2 gallons of premium so it was "close" at best. I also added a few capfuls to the tank after I soft seized and panicked! Side note, Honda GN2 residue on a shot glass ruins a perfectly good shot of Jameson! I "ran" pretty good afterward though.
eclark5483
Switch to 96:1. Those are outdated instructions.
Jonadz
Post by Jonadz »
For break in??? I could see after but that seems awful light for break in.
eclark5483
You're about at that breaking Mark anyway, so do it on the next fill up.
Jonadz
Post by Jonadz »
Gotcha! I calculated 2 gallons at my 30something mile per tank would get me close to 100 so figured I would more or less go by the can and not the odometer as much.
Jonadz
Post by Jonadz »
Just sent you a request on Facebook, any other informative veterans from here on there? Sorry for the thread clog by the way.
eclark5483
Several are on Facebook, meatball, 1man8scoots, Pat, etc.
eclark5483
And yes 96:1 sounds lite, you'll want 80:1 for break in, but 96:1 after, should be just fine, you don't wanna over saturate oil, so 50:1 is a little too much and can make you run lean (on fuel), and cause soft seizing.
Jonadz
Post by Jonadz »
Dang, think that may be why I soft seized? I'm atleast 50-1 if not slightly heavier. Was following the instructions Taz provided.
Jonadz
Post by Jonadz »
Might also explain the small spot of oil I'm leaving under the kickstand everytime I park it for a while.... Extra lube for the crank case ;) was planning on tracking that down tonight.
eclark5483
Yes, that image you posted is outdated and was done before I had dyno analysis done. Taz should be revising that soon. I noticed he is out of stock on BBK'S for now on his eBay Store. I'm assuming he will revise instructions after getting more in. Bump it down to 96:1 you'll probably notice a better pickup as well. And if you drilled 3 1 inch holes already, cover 1 up with some duct tape, try to get a little better suction then what you have.
Jonadz
Post by Jonadz »
If I get the time tonight I'll get to some tinkering! Will report back.
Ahhh the ol' TAZ BBK woes. I burned up 3 of them kits before I finally cut my losses and moved on. Never ran right, kept throwing money at it, finally gave up and swapped in an Elite motor. In my opinion, keep a Spree a Spree. If you want more power, speed, torque, etc...get a different motor.
Jonadz
Post by Jonadz »
No woes here, just kinks. I'm a very UNDER qualified mechanic who's first project is this spree and so far it's been fairly simple to figure out and work though. Thanks to a lot of write ups I found here before I joined. I hope my luck is better than yours with the bbk but as of this point I have absolutely no complaints.
