Page 4 of 5
Posted: Tue Jul 10, 2007 7:41 pm
by Kenny_McCormic
are you running with an air filter? Do you do plug chops reguraly? What kind of oil are you using?
Posted: Tue Jul 10, 2007 8:10 pm
by my4sons
Looks like I maybe should have started a new posting, sorry.
Yes I'm running with an air filter, using 2 cycle engine oil and have never done a plug chop, haven't really had it in running condition long enough to have the opportunity, died on me after using it about 6 times after buying it last summer.
Posted: Tue Jul 10, 2007 11:26 pm
by Kenny_McCormic
does the oil say something about injection? if it doesnt then its probably too thick and not getting the engine the oil it needs.
Posted: Wed Jul 11, 2007 7:51 am
by my4sons
I'm not sure (had one of my sons bring some 2 cycle oil home from the marina they work at - it's used for jet ski's/PWC's), but will cyphon the oil out and get new stuff, any brand recommendations? Thanks
Posted: Wed Jul 11, 2007 8:24 am
by KHPower
I use the cheap 2 cycle from Walmart. Its called Supertech and I have never had a problem with it.
Posted: Wed Jul 11, 2007 8:36 am
by KHPower
Would it be a good idea to clean the bearing in parts cleaner and then lube it up nicely?
Posted: Wed Jul 11, 2007 3:37 pm
by Kenny_McCormic
my4sons wrote:I'm not sure (had one of my sons bring some 2 cycle oil home from the marina they work at - it's used for jet ski's/PWC's), but will cyphon the oil out and get new stuff, any brand recommendations? Thanks
Thats called premix oil its too thick to work and will burn up the motor. You need 2 stroke injection oil get some from a honda dealer
Posted: Wed Jul 11, 2007 5:17 pm
by jagojago
I say just bolt in the motor I sold you and see if it starts up
Posted: Wed Jul 11, 2007 6:48 pm
by KHPower
I probably will.
The peices fit like a charm but I ran into a BIG problem. The bearing in the new right side case is too big and my original bearings are on the crank. I dont know what to do , so I am probablly going to go to a place called Presision and get the right bearing and have them remove the old one off the crank.
Posted: Wed Jul 11, 2007 8:05 pm
by jagojago
Any local machine shop should do it for $5-$10.
Posted: Thu Jul 12, 2007 12:32 pm
by KHPower
I called the machine shop and they can probably help me with the bearing , but the guy I talked to on the phone said they couldnt remove it , but Ill ask when I bring the motor in , or else I have to go to our local Harbor freight and drop 50 bones for a bearing puller
Posted: Thu Jul 12, 2007 2:09 pm
by HuskieMobileMan
KHPower wrote:I called the machine shop and they can probably help me with the bearing , but the guy I talked to on the phone said they couldnt remove it , but Ill ask when I bring the motor in , or else I have to go to our local Harbor freight and drop 50 bones for a bearing puller
You should be able to get a jaw puller pretty cheap at a car parts store. Or rent one at autozone.
Posted: Thu Jul 12, 2007 4:03 pm
by KHPower
A jaw puller will not work due to how far it is down the crankshaft, the claws will not slide under so you basicly need a bearing puller.
I went to the bearing shop and they did not have anything in their library of bearings that would fit my crank , so I went to a machine shop and they are gonna fashion a sleve onto my new crankcase to accept the orinal bearing size. I guess I could of ordered a new crankcase half but I figured I might as well just use what I got and stray away from any more problems. Once I get the case back and attach it I will be off and riding. I had it running yesterday and noticed that the flywheel was off balance and rubbing, thatss when I new the original bearing for my crank would not work with the new case.
Although I have put alot of coin down to repair this scoot , its alot cheaper than the shop considering all of the parts I have added whole new kickstart assembly,electric starter ,engine fairings,bolts,flywheel fan and crankcase + labor around 600.00 bones for a shop repair
Posted: Thu Jul 12, 2007 4:25 pm
by HuskieMobileMan
KHPower wrote:A jaw puller will not work due to how far it is down the crankshaft, the claws will not slide under so you basicly need a bearing puller.
Make your own tool to pull them off. Get a timing gear puller ($15) and a thick plate of metal and a couple of long bolts (5/16 bolts should work). Drill a couple of holes in the metal to put the bolts through and attach with 2 nuts each and cut a slot for where the cranshaft will fit through in the middle of the metal. Slip it under the bearing on the cranshaft and torque down till it comes off. Kina like this tool:
Posted: Thu Jul 12, 2007 5:21 pm
by KHPower
I may do that , good idea.
I was planning on just leaving the bearing sit on the crank and when my part is ready (crankcase w/new sleave) pound it gently on there because thats where the bearing is gonna end up anyway regard less if I remove it.
Good idea? not sure ?
