PLEASE HELP! Resurrecting 1987 SE50P Elite and derestriction
Re: PLEASE HELP!!!!
plug gap is around .028 thousandths, put a new plug in if it hasnt been running in a year, replace trans cover and tell us what happens
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
Re: PLEASE HELP!!!!
So motor was oil-locked too huh? May need oil pump but i wouldn't worry about that yet, Might be small leak and a year would cause case to fill up. You can have my kicker case. I'll email you.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
- martynkim
Re: PLEASE HELP!!!!
I sure would appreciate the cover evilone, I sent you an email back with an address. Yes it was oil locked it wouldn't budge until I cleared it
- martynkim
Re: PLEASE HELP!!!!
Got another question, I noticed when I took off the carburetor that the filter was shot. I have a K&N style filter I can replace it with. What do you think?
K&N
Many poo-pooh the K&Ns. I ran one and found it indistinguishable from the UNI Pod variety. They are heavy and that can be an issue on spigot-mount carbs, but the performance is no different.
Be careful tightening up those 8mm hex bolts on the carb flange, too. If they're stripped out - a common problem - re-tap the carb flange's threaded holes with 1/4", or Heli-coil.
You will need to jet up considerably from the size that suited a stock airbox - perhaps up to 90 or more with a stock everything-else. Be sure to saturate the cotton mesh as K&N recommends with their red oil.
- martynkim
Re: PLEASE HELP!!!!
I'll give it a try but, If I have to rejet (I know nothing about) I'll just buy the replacement filter. This is a K&N Style not an actual K&N flange is too big for it but I thought I'd just buy a cheap funnel and sacrifice it to fitting this filter.
Re: PLEASE HELP!!!!
K&N makes a 1" size that will glom over the carb mouth. So does UNI. If you can remove a carb for cleaning, and operate a flat screwdriver, you can replace a main jet. Stock box is fine for stock block, but may limit a modded engine.
- martynkim
Re: PLEASE HELP!!!! [Resurrecting 1987 SE50 Elite -Ed.]
I don't think it is modded this bike looks all stock. I just have not looked into "how to" rejet a carb yet. It may need replacement parts anyway as the float is cracked im epoxy the float now.
- martynkim
Nice edit on my title! was that you wheelman?
for getting it running initally, i would just buy a stock honda filter element. that way you dont have to mess with jets yet. that is somethiing you will do after its running well and you want to modify it. im sure with a clean carb and a charged bat. you will get it to start.
- martynkim
YOu are probably right aerorob as I don't want to change things too much as it ran this way before.
- martynkim
d***, another failure I put the carb on after cleaning it and tried to start it. It wasn't even giving a hint of firing so i put my hand over the carb to choke it. Then the starter began to grind.
It must not be aligned properly AGAIN!!! I guess this kick cover is done!
I guess I should wait for evilone to send the cover before I really screw it up
It'll be there Tuesday, Wednesday at the latest. I sent it 2 day priority.martynkim wrote:I guess I should wait for evilone to send the cover before I really screw it up
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
- martynkim
Found the problem. Nut on the crank came loose making the pulley too far away for the starter to connect
- martynkim
Thanks evilone
I REALLY APPRECIATE IT!!
