Checkin in, first post... here at least
- KingJeff801
Re: Checkin in, first post... here at least
http://www.collegebikeshop.com/fiche_se ... &fveh=3635
Love me a stock Bando, this place is cheaper than bike bandit
2001 Elite S
72cc Corsa
24mm OKO
Scorpion Pipe
Pic and Vid post
Gun Post
Wrong Side Kings 4 Life
72cc Corsa
24mm OKO
Scorpion Pipe
Pic and Vid post
Gun Post
Chicago Ben
saweeet, i searched for that part number on collegebikeshop and snagged this one on ebay for 20 bucks free shipping
woot. thanks jeff
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0429122856
woot. thanks jeff
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
1000k Polini triples
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
- Trafficjamz
I think that belt only works with the ZX trans.Chicago Ben wrote:can anybody confirm 654x18x30 is the size belt I need ? Also it appears as though everyone likes bando belts....
Chicago Ben
yeah I think you are right, i went ahead and bought a stock oneTrafficjamz wrote:I think that belt only works with the ZX trans.Chicago Ben wrote:can anybody confirm 654x18x30 is the size belt I need ? Also it appears as though everyone likes bando belts....
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Chicago Ben
the parts are slowly coming in... clutch arrived from daywot today
medium keli and he threw in 1k polini springs
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Chicago Ben
so my new belt came today
markings on the belt are 'zijingang vs belt'
'641 15.5 30'
is this correct, can anybody confirm?
'641 15.5 30'
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Yes, 641 length is stock for Aero and SE/SA50 Elites, all models.
Note that when you run a tape measure around the outside, you'll measure 650-something, depending on brand. It seems that manufacturers like to use some theoretical mid-point measurement, not the actual outer circumference.
Chicago Ben
Thanks Wheelman, you are always helpful.Wheelman-111 wrote:Greetings:
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Chicago Ben
Crank bearings, transmission gasket came in from bike bandit today.... add it to the pile
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
- Trafficjamz
Nice.... can't wait
Chicago Ben
I know man, I sat here and cleaned up the engine a bit today. I lightly went over some grime with a brillo pad so its not so nasty when you receive it. I also removed the electric starter motor and cleaned it up a bit and tested it. Cleaned up the crank case covers too. Also removed the rear brake, going to order new shoes for that this set has seen better days. I put the engine on a scale it was about 30.8 lbs. That plus all the parts is going to be an expensive shipment. Not too excited for that part haha.Trafficjamz wrote:Nice.... can't wait
The bulk parts order should be in next week.
this isnt the after picture its just a picture before i really went at it ha
testin' the starter
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
tospreeornottospree
- Goped
sweet a new tjamz shop project another monster going to come alive!
- Trafficjamz
If you clean it all up, What am I supposed to do?Chicago Ben wrote:I know man, I sat here and cleaned up the engine a bit today. I lightly went over some grime with a brillo pad so its not so nasty when you receive it. I also removed the electric starter motor and cleaned it up a bit and tested it. Cleaned up the crank case covers too. Also removed the rear brake, going to order new shoes for that this set has seen better days. I put the engine on a scale it was about 30.8 lbs. That plus all the parts is going to be an expensive shipment. Not too excited for that part haha.Trafficjamz wrote:Nice.... can't wait
Remember to drain all of the trans oil before you ship it. If a package is leaking UPS will not ship it.
Wrap it up in a garbage bag just in case
Chicago Ben
you so smart traffic. drained that tranny oil today. a) didn't even look like i had enough in thereTrafficjamz wrote:If you clean it all up, What am I supposed to do?![]()
Remember to drain all of the trans oil before you ship it. If a package is leaking UPS will not ship it.![]()
that aside the engine is pretty good to go shipping wise. I taped up various areas with blue painters tape. not sure if you remember but I was running my moped with no kickstart. I found the main components too the kick start today in an old parts box I had... but I had to order a few various pieces to the kick start assembly. I'm just going to ship it to you with no kickstart on it. I also ordered a new gasket for the left (kickstart side) of the crank covers.
I lost these bad boys over the years
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Chicago Ben
Cue in some Phil Collins.... I CAN FEEL IT , COMIN IN THE AIR TONIGHTTTTT
OHHH LORD
IVE BEEN WAITING FOR THIS MOMENT... FOR ALL MY LIFE....
no seriously. my 52mm Ruima bbk came from Tobaggan. Here are some gratuitous pics.
Now this all aside... all these parts are coming in great and all. A little speedbump in my life has kinda put a damper on the project. I have 3 roomates here in Chicago and one has a tendency to party a little too hard... so hard that it has our landlords on edge.... with that said I'm in the process of moving at the end of September. We all know how that goes, putting down first and last months rent/deposit... blah blah blah. So until I get that situation under control, the moped build is postponed. Booo right? Should be alright after I move into my new place.
OHHH LORD
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
