Page 5 of 15
Re: scooter racing in the northwest pics/video 1st&4th page
Posted: Wed Aug 11, 2010 2:48 pm
by az_slynch
bakaracer wrote:The guy that beat me was on a 166cc kitted vespa with full aftermarket suspension. I'm on a 72cc malossi ,stock crank setup.
Baka, the bike that beat you is a smallframe Vespa. Largest stock engine displacement on those motors was 121cc (called 125s) and the biggest, baddest setup for those motors is 152cc with a stroker crank and a Falc cylinder. In order to hit 166cc, he'd have to stuff the motor from a largeframe Vespa into the chassis, particularly a 125/150cc motor and a Malossi kit on it. I did see a P/PX-series bike in the race (the one with the turn signal holes in the rear of the cowls). Not sure if swaps like that are legit, but I figured I'd mention it. Heck, smallframes are like 75% scale vespas and weigh a fair bit less than the big bikes. P-series bikes weigh about 235lbs and the 125cc smallframes weigh around 165lbs.
Posted: Wed Aug 11, 2010 3:29 pm
by bakaracer
I race in the 190cc mod class and open 190cc so they can mod those bikes to 190cc.the guy that beat me has major engine work .he is using a piston for a motorcycle and had the cylinder decked because the piston pin height was lower and also to get the port timing right. So the bbk kit has been oversized too. They are all using 30mm mikuni carbs on there setups. Either way they have twice the cc and twice the hp I'm running and weight difference is around 67lbc between the bikes which isn't much.you have also consider that there bike is lighter also because of stuff taken off for racing so that stock weight is flawed. Mine will be heavier than the stock weight as I added oil filled front shocks and heavy duty rims to the bike. Not much weight around another 3 or 4 lbs.
Posted: Wed Aug 11, 2010 3:35 pm
by bakaracer
I pin point these things out so that if there are guys out there that want to race but see that there are bikes they are racing against that have more power or more cc's then them that they still have a chance to either win or take a podium spot with a smaller under powered scooter.
Posted: Wed Aug 11, 2010 10:55 pm
by elitedio
Nice Video Baca. Reminds me of the old days,
I liked your explanation of why you choose a smaller bike than your competitors. :thumbsup:
Posted: Wed Aug 11, 2010 11:37 pm
by bakaracer
I choose the elite because I know it better had parts for it and I raced on one back in the day so I feel more confident racing one. plus I wanted to see if I would have a chance racing against the vespas. just wanted to be the true under dog on the track.
Posted: Thu Aug 12, 2010 9:55 am
by bakaracer
Any of you seattle/tacoma area guys want to do a practice/track day,let me know.looking at doing one on Friday the 27th of this month. The weekends are already booked for kart races and other events. Cost is $50 for 3 hours of trck time. If we get enough guys they might give a cost break.
Posted: Thu Aug 12, 2010 12:16 pm
I just watched the video, riveted. Much respect. It's great that you stayed in contact with a bike that has 2.3x more displacement. Even better, you continued to run your own race and stayed smooth. Obviously your opponent made all his time on the straightaway.
Posted: Thu Aug 12, 2010 1:17 pm
by bakaracer
Thanks! I tried to push him to make a mistake.I might try out my mini stroke setup at practice to see if it holds up to the hard track riding.
Posted: Thu Aug 12, 2010 2:48 pm
I'm amazed you still had brakes at the end of that heat!
Posted: Thu Aug 12, 2010 3:27 pm
by bakaracer
Thank goodness for race brakes. Ncy ones in the front and ebc ones in the back
Posted: Thu Aug 12, 2010 3:29 pm
by bakaracer
I should race my stock 87 and swap the dio motor and race on the stock front brakes to show that the stock 87 brakes in the front can handle it too.
Posted: Sat Aug 14, 2010 12:07 pm
by bakaracer
OK you seattle guys. There is a supermoto race the 29th of this month at the PGP kart track. the just put a scooter class and race what you brung. you can wear either full leathers,motocross gear, or jeans with pads and riding jacket or leather jacket with gloves and a helmet. more info of the race and place can be found here http://pacificgp.com/
Posted: Mon Aug 16, 2010 11:42 pm
by bakaracer
come on out and check the action out.it starts at 9am so get there early as heat races start at 11am.
Posted: Tue Aug 24, 2010 9:54 am
by bakaracer
Don't forget you seattle/tacoma area guys. This Sunday supermotard/scooter racing at pacific raceways. Starts at 9am so get there early for the action
Posted: Fri Aug 27, 2010 3:03 am
by bakaracer
bump................
