this is what happened
Re: this is what happened
ur going thru the same im going thru..try a 138 main...i found that seems to b the one that does mine the best..hope you have the 10 pack jet kit
1988 yamaha zuma
polini evolution kit
polini evolution 2 exhaust
polini big reed manifold
dellorto 21mm
keli clutch
keli variator
dellorto 21mm
keli clutch
keli variator
oh and bogging...what rollers and gear setup do you have...mines not bogging but its a little sluggish off the line until about 15mph..then its stupid fast..like seriously unsafe for such a small scooter..anyways..i have a very tall gear and still come out the hole decent so make play with ur rollers and the jets and you will find the sweet spot
1988 yamaha zuma
dellorto 21mm
keli clutch
keli variator
dellorto 21mm
keli clutch
keli variator
- Goped
so then whats the signs that you need diffrent pilot jet
1995 honda elite
50mm big bore
v8 pipe
high performance cdi and coil
50mm big bore
v8 pipe
Bogging down from idle to wot sometimes to the point of stalling. A small pilot jet will not fill bowl enough and when you hit wot there will not be enough fuel, ending in a bog/stall.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
- Goped
i see, thanks for the info
1995 honda elite
50mm big bore
v8 pipe
50mm big bore
v8 pipe
The pilot jet has nothing to do with the fuel level in the float bowl, that is controlled by the float and the needle and seat.evilone wrote:Bogging down from idle to wot sometimes to the point of stalling. A small pilot jet will not fill bowl enough and when you hit wot there will not be enough fuel, ending in a bog/stall.
The pilot is basically a mid-range or intermediate jet that feeds fuel to the venturi before the main jet system starts flowing fuel. A stumble off idle or lazy preformance up to about 1/3 to 1/2 throttle can point to the pilot being the wrong size. Also high CHT temps when the throttle is shut off after WOT points to a too small of a pilot.
What he said ^^^. Now i see my reply was made in haste and the pilot does not control fuel bowl level
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
