86 spree just bought runs like crapp..nedd help!!!!
- KillinSpree
Re: 86 spree just bought runs like crapp..nedd help!!!!
Do the steps that we all gave you in this thread and youll be all set
1984 Honda Spree White
1987 Honda Spree Blue
- fastplastic
pretty sure he meant 1/4'' driveWheelman-111 wrote:Some use the 1/8th drive
Yeah, 1/4" drive.
Yeah, 1/4" drive.
are the spree petcock and the petcock from the 89 sb50p the same
spree parts for sale
still learning alot ..thanks to all on this fourm
if you have a good spree jug ..pm me if you want to sell it
Not even all the Spree petcocks are the same.
The '84 and '85 Spree are the same as the as the 1985 Aero 80 and 1985 Elite 80, 125 and 250.
While the '86 and '87 Spree fits a total of 40 different bikes including the SB50, 1988-90; the SA50 1988-94 and the Elite 80 1986-2007.
I know that the latter is still available from Honda.
i think i found my problem for sure ..i sprayed a litle carb cleaner buy the oil pump then it died down a bit then would rev up.. how would you advise me to seal that up.. iv never had one off so idk if there is like a o ring holding it on or what .. help me out
how would i fix a vacume leak at the oil pump???
Check the service Manual. There is an O-ring around the pump body.
Turf and Irrigation supply stores can match size for replacement.
Remember it could be case halves gasket and even reed block, which can crack. Clean thoroughly and observe for oil seepage elsewhere.
ok cool
the leak could also be coming from were the tw0 halfs of the engine case meat up?????
Yes.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
ohhh man i hope not ..
