Page 5 of 21
Re: Sprelite The Begining Of My Epic Build
Posted: Sun Apr 24, 2011 9:33 pm
by SpreeMadness520
Thanks. I still need a tire and a shock, What shock did you use?
Posted: Sun Apr 24, 2011 11:19 pm
by Petrock's 1984 Spree
I used the 94-01 elite shock because i managed to find an engine with half a frame.
And i just relocated the shock mount right under the VR mount
P1010842 by
jpetrak, on Flickr
IIRC the spree shock is about 1/4'' longer than the elite shock but it has a little different coil over. Im guessing that the elite shock is a bit stiffer because the elite is rated for a heavier rider, so the shock has to support that much more weight. All a guess though
Posted: Mon Apr 25, 2011 8:32 pm
by SpreeMadness520
Thanks to Trafficjamz I got a jet, Bought a tire of the correct size today. Now waiting on someone with an Elite E Shock and a unifilter....
Posted: Mon Apr 25, 2011 8:39 pm
by xxjareebxx
SpreeMadness520 wrote:Thanks to Trafficjamz I got a jet, Bought a tire of the correct size today. Now waiting on someone with an Elite E Shock and a unifilter....
look on ur fs thread i think i have one for you
Posted: Wed Apr 27, 2011 8:58 pm
by SpreeMadness520
New tire should be here soon, Also the honda elite E shock is on its way
I need to stop by fastenal to get a m10x140mm bolt to weld for the new shock mount
Posted: Fri Apr 29, 2011 7:25 am
by SpreeMadness520
Ok the build is starting to move along quickly, Got the Elite E shock, M10x140mm bolt, A unifilter (thanks Kingjeff) and the tire should be here soon. I will weld the bolt to the frame monday and run gas and vacuum lines AND IM READY TO RIDE! Stock
Posted: Fri Apr 29, 2011 12:07 pm
by Trafficjamz
SpreeMadness520 wrote:Ok the build is starting to move along quickly, Got the Elite E shock, M10x140mm bolt, A unifilter (thanks Kingjeff) and the tire should be here soon. I will weld the bolt to the frame monday and run gas and vacuum lines AND IM READY TO RIDE! Stock
I want to race you while you are still at 49cc.
It is the only time I may be able to beat you.
Posted: Fri Apr 29, 2011 2:50 pm
by SpreeMadness520
MAY be able to beat me....
Posted: Sat Apr 30, 2011 8:28 pm
by SpreeMadness520
New tire,Shock,And bolts
Posted: Mon May 02, 2011 4:30 pm
by SpreeMadness520
I welded the new shock mount and the shock is like 1/8 inch from hitting the Fu@k!ng tire
time to cut it off and re-weld...
But i have to admit it did look Bad@ss when it was all together. Thanks kingjeff for the uni.
Posted: Mon May 02, 2011 4:42 pm
by fastplastic
did you use any washers to space the shock out correctly?
Posted: Mon May 02, 2011 4:53 pm
by SpreeMadness520
Yeah of course still didnt add much room, I didnt weld the bolt with enough thread. Good thing I bought 2
Posted: Tue May 03, 2011 2:12 pm
by fastplastic
if you use the drill and weld way its alot easier if you got the right size bolt
Posted: Tue May 03, 2011 2:49 pm
by SpreeMadness520
I just re welded the bolt so there is more thread to keep it away from the tire, And the weld job is SEXY
Posted: Tue May 03, 2011 4:25 pm
by fastplastic
hurry up only 2 more days till race day
