Bolt On Spree-Dio swap Shock Mount SLOPE DISTANCE TESTER....
richdavison34
Re: Bolt On Spree-Dio swap Shock Mount SLOPE DISTANCE TESTER
Post by richdavison34 »
You have to do a bolt on spree/dio engine mount now. :thumbwink:
I'm down for the challenge!!
I need some pics/specs. I have no idea how that mount needs to look. Is the idea to make your spree match the Dio mount, or to make the Dio mount match your spree?
P.S. I haven't forgotten about the grab bars.
1984 Honda Aero 50.
Carb Swap. Cone filter.
seamus
Post by seamus »
frickin' awesome, dude.
don't forget to make your jigs!
Petrock's 1984 Spree
Post by Petrock's 1984 Spree »
I think the way to do it would be to get an elite motor mount and go from there.
Then basically replicate the piece with a smaller bushing-bushing length up front
That looks great :2thumbs:
Complete NOOB, sorry dudes
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-Polini 2 Shoe Clutch
-Koso Vented Clutch Bell
-669x18x30 Belt
richdavison34
Hmmm. Anybody got pics of this?
Is there an offset that needs to be accounted for? I remember reading something about have a 1'' offset to one side or the other.
1984 Honda Aero 50.
I think you should start with a spree mount and add to that.
Remember this should fit with out having to cut anything off the spree.
Also make it so the center stand can still be used :wink:
richdavison34 wrote:Hmmm. Anybody got pics of this?
No one inch offset, that was my own stupidity on my build :oops:
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
richdavison34
I'm going to have to put my eyes on exactly how this needs to work.
The elite engine mount is the same as the elite "dio" engine mount, correct?
I pictured the mount as being a part of the lower crank case (non removeable). I have to assume that isn't correct.
When I go back to SIX's house, I'll see if he can show me an elite mount.
1984 Honda Aero 50.
KingJeff801
Post by KingJeff801 »
heres pics of the grab bar mounted
grab bar2.JPG (108.39 KiB) Viewed 6385 times
grab bar1.JPG (101.24 KiB) Viewed 6385 times
2001 Elite S
72cc Corsa
24mm OKO
Scorpion Pipe
Pic and Vid post
Gun Post
Wrong Side Kings 4 Life
richdavison34
Good deal!
Thanks again!! :smile:
Can't wait to start working on this.
1984 Honda Aero 50.
Mystic
Post by Mystic »
I am in the process of doing the engine swap right now, I could definately use one of those shock mounts :D Havent started on that yet still trying to get all the pieces for the motor, I got it at the salvage and it was missing a few key elements :D
richdavison34
Just let me know when you need one, and I can hook you up. :smile:
1984 Honda Aero 50.
Mystic
Post by Mystic »
I'm ready whenever you are. How much you charging? :D did you make it for use with the Spree shock or the elite shock? or does it even matter which lol
richdavison34
PM Sent.
1984 Honda Aero 50.
Trafficjamz wrote:I think you should start with a spree mount and add to that.
richdavison34 wrote:I'm going to have to put my eyes on exactly how this needs to work.
Lay your eyes on this. :wink:
This is the piece that is in the way.
So........yeah.....make a motor mount that fits, but with no cutting.
And remember to leave room for the center stand.
richdavison34
TrafficJamz, Wheelman, 66Six....my favorite guys on this forum.
Great pics TJ!
The width needs to be cut down as well right? On the Elite mount that is.
1984 Honda Aero 50.
