...14 grandDaylightDies wrote: 90's Jogs, Dios, Ruckus, and Zuma sell for $14,000 out here in Japan. No joke from a used dealership with a warrenty. It is rediculously expensive.
Wow has it been a while! wanna make a gyro faster?
Re: Wow has it been a while! wanna make a gyro faster?
New to scooters, but old to riding anything with a motor that been modded. Had a gyro now sitting in the shed for three years that half * runs. When it wants to that is. So I started palying with and found the compression was weak. Searched the webb for weeks and found my way here. Really need a piston and rings to bore this thing jsut so it will run again. The crazy mods can come later. So who can hook me up?
- bradthreee
Welcome papa Pete.
Have you tried the dealer?
Greetings Papa Pete...
Start your quest for Gyro piston/parts by posting your own thread instead of tagging on the tail of this one...you will have better help that way. You will want to get advice from mousewheels and/or tazland001 with this gyro topend build. "taz", as we call him, may have a 44mm piston set-up that will do you well for this job. What you need will depend somewhat on the condition of your cylinder. Get it apart, take some pix, and post your findings for us to see. Some day I will need to copy your build as I have 3 gyros as well. Welcome to the board sir, and I hope it serves you well...
Can't one of the Aero 50 pistons be used as a stock high compression replacement?
I have not found any piston available for the Gyro from Honda or anywhere else, so that's why I jumped in here. The topic is wanna make gyro faster? I figure why watse time hunting for stock when I can mod it up with the info from this thread.
Post a Want-to-buy ad...that will get the attention of someone who can supply your part...motormike wrote:Greetings Papa Pete...![]()
Start your quest for Gyro piston/parts by posting your own thread instead of tagging on the tail of this one...you will have better help that way. You will want to get advice from mousewheels and/or tazland001 with this gyro topend build. "taz", as we call him, may have a 44mm piston set-up that will do you well for this job. What you need will depend somewhat on the condition of your cylinder. Get it apart, take some pix, and post your findings for us to see. Some day I will need to copy your build as I have 3 gyros as well. Welcome to the board sir, and I hope it serves you well...![]()
-- Stock replacement parts --I have not found any piston available for the Gyro from Honda or anywhere else, so that's why I jumped in here
Link to Wiki topic with Gyro info.
-- Gyro pipe --
Only MySpree knows what he did, and may someday tell. A GoPed pipe pipe experiment in MS Paint has some resemblance.elitedio wrote:Did you [ed: Myspree] make it from scratch or adapt it from something else. It looks vaguely familiar.
- Go_Ped_Mods.JPG (32.55 KiB) Viewed 5258 times
- tazland001
I will have the 44mm piston kits in a month
Taz
Taz
Thanks for the interesting read.... Ive got a 84 gyro too... whats the first thing youd do to it to get some extra power outta it? Have you still those over size pistons?
Brian
Brian
